housing and iron painting?
Old 04-15-14, 05:54 PM
ricardo.benin's Avatar
Hi I just bought some 550°f vht paint so I can paint housings and irons before engine is built so my question is how hot does the outside of a 13b get is the normal temp higher then 550°f.
Thanks
Old 04-17-14, 06:37 AM
FD Project
BLACK MAMBA's Avatar
You will be fine with that paint, make sure to wipe down the parts with acetone before painting.
Old 04-17-14, 06:55 AM
Less Cubes, More Balls
spokanerxdude's Avatar
WA
Try and keep paint away from the exhaust ports unless you like smoke and burnt paint smell every time you run your engine, at least for a couple of days anyway.
Old 04-17-14, 02:09 PM
Ok thanks for the info just one more question, I can not find high temp primer were I live so do you think I can go primer less or should I just order some high temp primer from online.
Thanks
Old 04-17-14, 04:13 PM
FD Project
You can go without the primer.
Old 04-17-14, 06:55 PM
Sharp Claws
RotaryEvolution's Avatar
the outside shell of the engine rarely goes much higher than 200F, some areas are hotter like near the exhaust.
Old 04-17-14, 09:28 PM
Ok thanks for all the info but is there any problems with going primer less.
Thanks
Old 04-17-14, 10:53 PM
Samito Built's Avatar
Thanks
No, you don't need primer just clean the parts good and you'll be fine!
Old 04-18-14, 12:15 AM
Ok great I just ran parts through parts washer so paint should stick pretty well.
Thanks
Old 04-18-14, 06:44 PM
rx3sum's Avatar
Spray them with brake cleaner before painting.
Old 04-21-14, 08:44 PM
Thanks for the help guys, here is results.
Thanks
cristoDathird
Introduce yourself
28
05-30-19 08:47 PM
stickmantijuana
20B Forum
8
08-18-15 02:46 PM
Quick Reply: housing and iron painting?
