Help with 3bar map sensor *gm and pfc)
Im looking into getting a gm 3bar map sensor.. Can someone just clarify, the one banzai sells is just a gm 3bar sensor with the harness right? if i just buy a 3bar map sensor by itself i just have to hardwire it in or make a harness correct? do i have to calibrate it or anything or is it straight plug and play?
if i have to wire it, can someone provide a diagram with what wires to connect to each? and where i can buy a pig tail for it? thanks
Ours is a plug and play harness, so that you do not have to worry about soldering wires or crimp connections falling apart. http://banzai-racing.com/store/3bar_...r_adapter.html
All GM 3 bars need to be set up on the PFC with a datalogit.
SSS-TUTUTU
I just did a gm 3 bar on mine.
its not hard at all if youre capable, ive seen your build thread so this should be a walk in the park for you. just snip the harness and rewire.
I also got my gm3 bar with pigtail for 90$, all i had to do was stab my pigtail with 10" of new wire. banzai wouldnt sell me the harness seperatly because they say people were using them on different 3bar sensors....etc..i dont know
you also need to rescale the pfc, and you need a datalogit to do so. 4100 offset 0. dont quote me, if you end up going this route i can check for you, or its readily avail by searching here.
That is not what was said. We do not sell the harness on its own because we got tired of dealing with tech issues from people that bought 1 bar or 2 bar sensors (or some other sensor) from forum members or ebay that were sold as 3 bar. We sell them as a set this way the buyer knows that there will not be any installation issues.
lol i know...
banzai = good plug and play no headaches
muibubbles= cheap and if i can get the sensor for 50 why not do it for half? the harness is not worth $60 to me if i can save that by making my own harness... after butchering my whole cars wiring, a little sensor is the least of my worries.... i just wanted to know if there was more science behind it
Eye In The Sky
on
Originally Posted by IRPerformance
Cheap is all good until you get a fake sensor that fails.
24seven_dada
20
11-10-18 12:03 PM
mulcryant
09-09-15 05:24 PM
