FC3s with 13b-REW Swap?
Old 08-20-12, 12:00 PM
CowboyTayy's Avatar
Well, I might be trading my beloved S13 Coupe for a 91 Vert FC.
He said the Apex seals are bad in the N/A engine, but.. He'll throw in a FD3s engine swap, for free.
He told me all I need to do, to do the Swap is get motor mounts, Intercooler, and piping.
I'm not finding alot of information on this swap? I'm probably not researching the right thing.
Is there ANY Custom fabrication necessary?
I need to know, as soon as possible. What I need to do. (: Looking at the car today.
Thanks guys!
Old 08-20-12, 10:27 PM
Top Down, Boost Up
RotaryRocket88's Avatar
Uh, you could say that: FC3S Pro v2.0:&nbsp Engine Swaps - 13B-REW Engine Swap
It's not a bolt on.
Old 12-03-12, 11:34 PM
audoetuk's Avatar
Ok so what if you wanna just use the housings/irons from the fd in an fc? Is it the same as swappin the whole motor?
Old 12-03-12, 11:41 PM
fc3sfreek's Avatar
No that won't work unless ur making custom manifolds, etc. HOWEVER! I do have a custom mount made for swapping a rew into an fc. Literally bolt on using fc mounts. Pm me if interested.
Old 12-04-12, 12:02 AM
audoetuk's Avatar
So cost wise I'd probably just be better off porting the fc motor, that's fine with me I was just wondering, since the fd ports are a lil bigger. Appreciate it.
Old 12-04-12, 12:21 AM
fc3sfreek's Avatar
Well an n/a fc engine 146hp compared to a REW 260~hp it's a huge difference lol. And if he's offering the full swap I'd take it.
Old 12-04-12, 01:01 AM
audoetuk's Avatar
Na I'm straight, I can make plenty power on my 13bt, most big hp fc's still have fc motors anyway, I was just thinkin about the idea.
Old 12-04-12, 01:13 AM
fc3sfreek's Avatar
I just realized u aren't the OP lol that's y I figured it was an n/a motor
Old 12-04-12, 01:15 AM
fc3sfreek's Avatar
It's hard to get more than 400hp out of a 13bt unless ur bridging or P-porting it though. My HP goals were 550-600 that's y I was going 13brew
Old 12-04-12, 12:21 PM
audoetuk's Avatar
Na I've seen much more, close to 700whp on mild ports. Right tune and turbo you should make 500whp fairly easy.
Old 12-04-12, 07:40 PM
GK1707's Avatar
^Thats badass. 13b rews seem to be the motor of choice when going for major power. I like the reliability of the 12a though
Old 12-04-12, 07:43 PM
audoetuk's Avatar
That was on an Fc motor ;-)
Old 12-06-12, 06:25 PM
RotationEvolution's Avatar
Unless you want to show off you have a 13B-REW in your FC, S5T engine can do about the same. 13BT 300whp+ is really not that hard to achieve if you have the right parts or you/your mechanic know what he's doing.
I had a large street port w/hybird turbo powered by LT-10, I was running about 310whp@16psi. Good luck on your trade!
Old 12-18-12, 09:58 PM
audoetuk's Avatar
Forget 3-500hp, I'm shootin for 600 and up haha...the most I've seen is 605whp on a 13bt with e85...same fuel with an s475, someone I know, white 9 sec fd, named Roan, made 746whp and 805 on e98...street driven too.
Yall should look up motivefab.com, they have mounts that solve the mounting issue, another friend I have runs those mounts in his fc and vouches for them, I'm lookin into em now.
cooldude
West RX-7 Forum
10-03-15 09:17 PM
sinistersam
09-13-15 07:17 PM
Quick Reply: FC3s with 13b-REW Swap?
