Rx7 wont start after rebuild
Old 12-29-12, 12:55 PM
justindeorx7's Avatar
hey every one i have just finish my first rebuild on my 87 6port na rx7 car wont start everytime i crank it it makes a tss tss tss sound then sometimes backfire ?? idk what to do at this point timing was set by a friend :/ engine just jumps as if it wants to start i tried the oil trick by putting oil in the chamber and thats when it started backfiring engine just keeps flooding i just keep on unflooding it -_- im trying my best can someone give me some advice -__-....
Old 12-30-12, 10:24 AM
Engine, Not Motor
Aaron Cake's Avatar
Check the position of the CAS. It's likely that it was installed incorrectly, leading to wildly wrong timing.
Old 12-30-12, 11:10 AM
rmx5's Avatar
maybe the cas gear in the E shaft was installed backwards...causing timing to be wrong.
Old 12-31-12, 10:12 PM
Hey I checked back the cas the engine kept on flooding and jumping as if I was trying to start and then backfire but I dont think the cas isnt installed crrect what do I do to install it correctly? Do I line up the e shaft pully with the in on the block and line up the cas with the ntch at the bottom? I really want to drive this car and Aaron cake are you the person that build project Tina??? If so great build!!!
Old 12-31-12, 11:01 PM
CrimsonPride's Avatar
I think to really make sure everything is right you need to do the procedure for finding TDC on the front rotor. search/archives should have it. IIRC you pull the plugs from the 2nd rotor and turn the engine until you see an apex seal in the plug hole (leading?) with an inspection mirror. This will be TDC on the front the CAS should be aligned with the engine in this position, again IIRC, so do a search.
Old 01-01-13, 09:25 AM
ok i will try that ...
Old 01-01-13, 10:36 AM
satch's Avatar
Post #9. https://www.rx7club.com/2nd-generati...estion-978911/
Old 01-01-13, 06:50 PM
thanks i will also try that tomorrow as soon as i get off from work
Old 01-01-13, 08:27 PM
Retired First Sergeant
Boriquaguerrero's Avatar
i was having the same issue last week but once i found the TDC and installed the CAS correctly the car started right away!!!
Old 01-03-13, 01:25 PM
ok i now have the time to work on it i am home im going to work on it write now!!!
Old 01-03-13, 02:21 PM
flaco's Avatar
maybe compression is low
Old 01-03-13, 05:00 PM
TaK
ghost1000's Avatar
Good luck setting the timing here are some tips.
1 take the cover off of the cas and mark the top in relations to the mark on the bottom.
2 line ur engine timing marks and drop in cas. U can now see its position with the dust cover off.
Old 01-06-13, 10:07 AM
Still cant get her to fire up....
Old 01-06-13, 10:11 AM
Engine, Not Motor
Aaron Cake's Avatar
So did you verify that the CAS is installed correctly? And that the spark plug wires are in the correct position?
Maybe the thing is now totally flooded. Tried unflooding it after fixing the CAS?
Worst case, a push start with another vehicle always works.
Old 01-06-13, 06:18 PM
yea i installed the cas in rite but it like just keep backfiring -__- idk y and yea i kept on unflooding it but my battery keeps dieing to fast.. :[
Old 01-06-13, 06:29 PM
Bridge Port Freak
ArmyOfOne's Avatar
Backfiring is definitely pointing at the CAS being installed wrong.
Old 01-07-13, 11:30 AM
TaK
ghost1000's Avatar
Check the cas with a trimming light to see where it's firing. U only have to be close to get it running.
I think ur problem is something else wish I could see the car myself.
U need four basic things to run an engine no matter how much bs is on it.
Air
Fuel
Compression
Spark.
It's less complicated than u might think
Old 01-07-13, 02:07 PM
Well today I completely unflooded the engine and well I found out that the the coil pack that fires the two bottom spark plugs wasnt sparking at all.... So I check the wire and plugs there fine but the coil pack isnt...could that be y??
Old 01-07-13, 02:24 PM
satch's Avatar
That would be the leading coil. The coil has a plug w/two wires, one is Black/Yellow and the other is Green/Yellow. The B/Y wire should have 12 volts w/key to on. The coil itself must be bolted to the fender to receive a ground or it won't fire.
Old 01-07-13, 06:31 PM
well there was water in it when i took out the spark plug wires.... my friend had spilled all og his water on it when we were doing the build -__- so yea it is getting 12volts when the key is on but not giving any spark at all .... but could that cause my engine to not start?
Old 01-07-13, 08:03 PM
satch's Avatar
An engine can start using only the trailing coil, but it would be hard to start and run rough. Whether it is the main cause for your car to not start is still a mystery at this point in time.
Old 01-07-13, 11:19 PM
HAUNTED HAMMZ's Avatar
What's your compression?
Old 01-25-13, 12:31 PM
didnt have the time to check the compression i am far away from the car i need a leading coil pack but i am sure the compression is good
Old 06-08-19, 09:56 PM
Nate Miller's Avatar
Question about your comment
when you say 2nd rotor do you mean the front rotor or the rear rotor in relation to the car
Old 06-08-19, 10:34 PM
rxtasy3's Avatar
rotor 1 is front, rotor 2 is rear.
Quick Reply: Rx7 wont start after rebuild
