Opinions on Power FC/remapped.
Old 03-05-13, 07:56 PM
jayscoobs's Avatar
Yeah true, I think I might just go with a chipped ecu for now. I still need to find a proper constant 12v for my gauges. I'm not good with multimeter since I blew a fuse last time. I think I want to move my gauges to the center speaker but I don't think my sensors will reach haha.
Old 03-06-13, 02:20 AM
Rotary Motoring
BLUE TII's Avatar
and as far as getting bad gas and racing... buy containers of your own gas and only use it when you go racing. $100+ a tank is cheaper than 5 blown motors.
Yes, that is what I am thinking. I did have one of those TII motors that lasted a good while because I only used it for racing and added 5 gallons 116 leaded to the tank every time. It eventually died when one of the EGT probes came apart and pinched a corner seal. I will go back to that and see what I can break without the help of detonation.
Old 03-06-13, 12:36 PM
Sharp Claws
RotaryEvolution's Avatar
water injection
Old 03-06-13, 02:23 PM
  #29
gross polluter
Tom93R1's Avatar
Fix everything that needs to be fixed first. After that, buy a PowerFC or something similar as your first performance modification.
I have seen way to many FD piles of crap driving around and it always is a result of people with limited financial resources buying things like intercooler, exhaust and body kit instead of fixing bushings, AST, and wire harness. Then they turn up the boost and end up with a shell full of bad parts.
Old 03-06-13, 02:33 PM
  #30
Tem120's Avatar
Originally Posted by jayscoobs
It's not that I don't have much money. It's just that mods come slow. I can't dump 4k at a time like a lot of people here. I'm just starting my career.
Prioritize what you want to do with the car , and as you drive it what you would like the car to do better.
but I would invest in a Wide band once you start modding.
Old 03-06-13, 03:10 PM
  #31
jayscoobs's Avatar
All maintenance is done with the car and up to date. Other than those bushings cuz they just started clunking. Still small stuff that has to be done thats more cosmetic than engine related.
Im fine with the power levels for now. I just hate that stock airbox cuz its a pain to remove and put back in. I mainly wanted a Power FC to monitor everything engine related.
Can someone point me to a good Constant 12V source? Last time I poked around with a multimeter I blew fuses. My gauges need switched and constant 12V. I can tap into cig lighter? But dash has to come out right?
Old 03-06-13, 08:10 PM
  #32
jayscoobs's Avatar
Oh yeah since we on the subject. I'm just planning on a M2 ecu or Pettit and what would be the mods for it? Catback, downpipe, intake, intercooler? Also upgraded fuel pump? Also need boost controller?
Old 03-07-13, 07:42 AM
  #33
Tem120's Avatar
How consistant do you need it to be ? Under your left kick panel there is the main fuse box . Use one of those it gets fed from the ignition . it will be constantly on aslong as your key is in..
Old 03-07-13, 10:07 AM
  #34
jayscoobs's Avatar
Gauges require a switched ignition 12v which I used at the fuse block as well as a constant always on with the battery.
Old 03-07-13, 10:38 AM
  #35
lOOkatme's Avatar
I suggest not going with a chipped ecu. save the money to buy the powerFC.
Only do things once IMO. Saves time and money.
If you think you are pushing the stock ECU with what you want to install, don't install it till you collect all the right parts. I think its more dangerous to run a modified car on a stock ecu than it is to modify the car and run the powerFC and tune it.
Old 03-07-13, 11:25 AM
  #36
jayscoobs's Avatar
Only thing that's holding me back from a power fc is no knock retard. The monitoring functions are nice but I'd hate to stare at the screen a lot. Much easier to read dials from peripheral view than looking at digital.
Old 03-07-13, 04:24 PM
  #37
Mr. Links
Mahjik's Avatar
The M2 ECU is a little more reserved than the Pettit. You can run full bolt-on's with the Pettit, and the Limited version will have fuel cut at 14.7. The key is keeping your boost in check (but that's no different than the requirements of any other ECU).
Old 03-07-13, 05:05 PM
  #38
AzEKnightz's Avatar
I guess I should chime in here and give my opinion about this.
As a mechanic, as a friend and as a FD owner. Keeping the car/engine running happy is my #1 priority.
Noises and other issues can come later. Therefore my conclusion to this is get a PFC to make sure the engine is spot on and running healthy FIRST, then save up for other things like fixing the bushings and any other upgrades.
TBH, when you're driving you will MOST likely not gonna read your "knock". But more so on Boost. Keep an eye on your boost/water temp would be something I personally choose over any other monitors.
1) Boost, you dont want to push it if it's spiking and over boost = apex seal failure.
2) Water temp, make sure you're up to temp before boosting and make sure your engine does not over heat in case a lose of coolant situation which can result rupture coolant seal.
Again, I prioritize my engine over anything else OTHER than safety issues that you will need to adjust to right away.
DO NOT WASTE MONEY on getting a chipped ECU like another member suggested. DO THE JOB ONCE and ONLY ONCE. <--- Work smart, not hard!
There you go, now think about it and make a decision ;-).
-Eric
Old 03-07-13, 05:21 PM
  #39
jayscoobs's Avatar
I was waiting for you to chime in lol. I guess knock isn't so bad since I was planning on water injection. One issue that I just remembered is the event of a really cold night, does the base map on a power fc adjust the maps for cold temps? I can't remember but I think I saw something where you need seperate maps for the cold nights and altitude changes? But I guess it wouldn't matter anyways because base map is rich to begin with?
Old 03-07-13, 05:36 PM
  #40
AzEKnightz's Avatar
Yes, it will adjust for colder weather as long as the car is in "close loop" for the O2 sensor monitor to kick in.
I believe the PFC will use the IAT sensor readings and adjust the map accordingly. Otherwise why would we even need that damn sensor right?
-Eric
Old 03-07-13, 05:42 PM
  #41
jayscoobs's Avatar
Actually the o2 sensor is what I remember. Because on Raymond's thread it says to disable o2 feedback. Which would give the ecu no AFR readings correct?
rx7shirley
09-02-15 02:11 PM
ChrisRX8PR
08-21-15 01:56 PM
Quick Reply: Opinions on Power FC/remapped.
