lightweight rotors =more horsepower and less torque???
Old 08-11-02, 12:12 AM
Will u do me a kindness?
the_glass_man's Avatar
I was looking into the RB lightweight rotors, has anyone used them??? I've heard that since they are lighter then stock they will give more horspower, but you will also lose torque. Is this true??
Please explain.
Old 08-11-02, 01:33 AM
87GTR's Avatar
I dont think they give more hp I think they are just like lightweight flywheel. it lets your engine rev faster but not more hp.
but if Im wrong let me know
Old 08-11-02, 01:28 PM
Old [Sch|F]ool
peejay's Avatar
Lightweight rotating assemblies don't add power or reduce torque. Put it on an engine dyno and it will still have the same static (RPM constant) horsepower.
Now, DYNAMICALLY, lightweight rotating parts allow the engine to accelerate quicker. More power goes to accelerating the vehicle instead of accelerating the engine itself. This makes the engine feel more powerful because the car will accelerate quicker.
This will occur at ALL RPM.
The "torque loss" sensation is a similar phenomenon, except it's mainly a problem with driving habits. The same lower inertia which allos it to accelerate faster, means that the engine will decelerate faster as well. This means that when pulling from a stop, you can't rely on large amounts of rotational intertia to start the car moving, you have to use more throttle. The engine doesn't have "less torque", it just has less inertia so you have to feed it more throttle when you're slipping the clutch to get moving. Likewise, when going up a hill and the car starts slowing down, the engine has less rotational inertia to help keep it going the same speed.
Again, both of these "problems" are driving habit problems. When pulling away fro ma stop, you should use the throttle and not rotational inertia to get you moving. When going uphill, if the engine starts slowing down (running out of power) then you're in too high of a gear anyway. Heavy flywheels and rotors simply mask poor driving habits.
Old 08-11-02, 02:34 PM
Aico's Avatar
With lighter parts you increase your redline. With the right mods you can make more power@high RPM
Old 08-12-02, 04:16 PM
silverrotor's Avatar
Beautifully explained peejay.
Old 08-18-02, 11:00 AM
Off riding sportbikes!
851stgen12a's Avatar
Thanks Peejay. YOu answered alot of questions I didnt even know I wanted to know.
Old 08-18-02, 03:23 PM
Pineapple Racer
pp13bnos's Avatar
Rob at Pineapple has a guy who does lightens them for him. Not to mention, they are alot cheaper!!
Old 08-18-02, 04:17 PM
W. TX chirpin Monkey
fastrotaries's Avatar
why are RB SOOOO expensive anyway. I"ve seen them cheaper elsewhere and still balanced.
Old 08-18-02, 05:01 PM
10.32 @ 133
AJC13B's Avatar
Aluminium rotors + aluminium cente/end plates =
Old 08-18-02, 06:36 PM
Yeah that **** is mad tight yo. And what the Hell is RB so damn expensive?
Sounds like something I'm going to look into for my next motor.
sinclair7seven
11
09-11-15 10:15 AM
doritoloco
09-05-15 12:41 PM
Quick Reply: lightweight rotors =more horsepower and less torque???
