Is my transmission toast? ...burnt clutch smell and slipping
Old 05-31-03, 02:27 AM
Speed Mach Go Go Go
GoRacer's Avatar
Unhappy Is my transmission toast? ...burnt clutch smell and slipping
Damn, well i've been noticing a burnt clutch smell but thought it was my turbos cause I know the secondary is toasters strudle. I also now and again felt the car slipping and thought it was the clutch. Never having a hydrolic clutch before I didn't know what to look for.
After being in gear cruising I step on the gas, the rpm skyrocket but the car only slights pulls. I get better pull if I slowly ease on the pedal. The boost gauge jumps as well but only to abut 6lbs.
Old 05-31-03, 02:41 AM
duboisr's Avatar
The clutch is gone but not the transmission. Replace it now before you waste the flywheel .
Old 05-31-03, 02:48 AM
Money Pit
Flyrx7's Avatar
I can't tell from your post, but are you talking about an automatic? If so it's time for a partial rebuild at least (new bands and clutches, etc). If you're talking about a manual then its clutch, clutch plate, and throwout bearing. Might even throw in a lighter flywheel too, at least get yours resurfaced. Don't forget labor too, about 3-4 hours for a shop to do it.
Frank
Old 05-31-03, 03:42 AM
Speed Mach Go Go Go
GoRacer's Avatar
Manual (I mention a clutch). I took it out again for a drive. From take off at 3k rpm's I let go of the clutch but the car barely moves. It does not buck and the rpms go up 3 times as fast or more as the speedometer. I can't call it slipping because it does not all of a sudden catch and go. It's light i'm towing a boat!
Old 05-31-03, 08:33 AM
gshaffer's Avatar
That is exactly what a slipping clutch feels like. If you keep trying to drive it you will damage your flywheel.
Old 05-31-03, 08:40 AM
Weird Cat Man
Wargasm's Avatar
I agree with everyone else. That is exactly what a slipping clutch does. Get a new one in there ASAP because every time you slip it like that, you are heating up the flywheel and pressure plate and possibly doing damage to them.
Brian
Old 05-31-03, 03:23 PM
Speed Mach Go Go Go
GoRacer's Avatar
I thought a slipping clutch was a delayed reaction. Is it different on a hydrolic clutch? On my CRX when the clutch slips, it all of a sudden catches after a few seconds and then goes. On the RX7 it catches right away but it feels like i'm pulling a damn oversized yaught!
Old 05-31-03, 03:43 PM
WTB** Very Low Miles 94-95
artguy's Avatar
yep...time for the act pressure plate and a new stock disk and thrwout bearing.
ive run that setup FOREVER and have had no slipping.
you will toast the flywheel if you take that disk any further...the disk is probably paper thin right now.
if you have access to a garage you can do it yourself over the weekend...its a bitch...a total bitch...but ive done it when i was low on cashola.
j
Old 05-31-03, 04:01 PM
Speed Mach Go Go Go
GoRacer's Avatar
^ Thanks bro,
Damn that sucks! That's the second race I can't make and now it will be to late to join MazdaComp before my rebuild. Now I have to put the Honda back together.
Old 05-31-03, 06:16 PM
artguy's Avatar
take it to the track and drive down at about twenty miles an hour to get your timeslip..hahha...then get your mazcomp stuff and get that streetport!
Old 05-31-03, 08:18 PM
elmo908's Avatar
just get an HKS flywheel. I hear good things among the older z car guys.
Old 06-01-03, 12:29 AM
Tunning till I drop!
James Paventi's Avatar
Looks like you might as well start your rebuild ... so when are you gona pick up my shop crane? <grin>
Let's pull the bad boy out ...
firzen
09-15-15 12:04 PM
Enzo1944
09-06-15 08:57 AM
ZaqAtaq
09-05-15 08:57 PM
Quick Reply: Is my transmission toast? ...burnt clutch smell and slipping
