A bit of info on Marvel Mystery Oil, and cleaning and lubricating of 13B internals
Did a bit of searching around the net. Didn't really get the results I was looking for. It would appear that the stuff is ok for use on our rotary engines, but I didn't find anything conclusive. I'm thinking of just changing my oil every 1000 miles and letting my MOP do it's job as far as the lubrication is concerned, and using the ATF trick as a periodical cleaning.
good write up on ATF trick:
http://haxx0r.net/car/rx7/atf.html
some synth/convential oil info:
http://autos.groups.yahoo.com/group/...e/message/3294
MMO:
http://pulsar.westmont.edu/aeronca/faq/mmo.html
MMO, scroll down to "in the fuel system:"
http://www.danford.net/marvel.htm
Take all of this with a grain of salt, as always.
MMO:
Waiting for the RX-9
on
Good to share the info, but some of it is totally outdated.
Mobil 1 has been approved for all rotary's
MMO is just the old 'Top Oil' a lot of ppl use to sell.
Some benefit, some snake oil effect.
Two stroke oil would be just as good. Use 200:1 and keep the OMP.
Originally posted by weaklink
interesting MMO info...thanks. The ATF link doesn't work, says FORBIDDEN. Have you ever used ATF personally?
I've used ATF to help start a flooded motor in extreme cases, but that's about it. I'm going to try the ATF cleaning trick when I get back to my 7.
Rich
Racing is life!
on
Thanks for the links. I always figured it was a type of "Top Oil" as stated above. I used it every tank in my first gens.
I've also considered using AMSOIL 2 cycle lube. That stuff is just a miracle cure for 2 cycle engines. I used to have to rebuild the (3) carbs in my outboard every 2 years. When I switched from dino 2-cycle to Amsoil, never had to do it again. Stuff burns very clean and it a strong detergent. I'm just not sure of the effect on the catalytic converter and all.
My theory has always been that you can never have too much lubrication. At least when it comes to car motors.
The Power of 1.3
on
Rich you must be bored over there. Lots of time spent thinking about the 7 and not defending freedom. j/k
Good info though. I'm glad someone took the time to put this together. Good luck.
on
Trending Topics
on
Can I ask a really dumb question? Ok, now that I have I got a couple others.
1) Since we *KNOW* 100 pct for a fact that synthetic oil is *BETTER* for the turbos and
2) Turbo's cost *MORE* than the freaking engine and
3) Any benefit or detriment that the engine may have from using synthetic or dyno juice is a moot point considering the life span of the 13B-Rew is not long enough for those factors to come into play, then the argument for synthetic for the turbos is more than irrelevant, huh?
Damn, I should be scientist or something.
5yr member, joined 2001
I use 4oz of MMO every tank. I know two guys who are both over 60 and have worked on heavy, diesel-powered machinery forever. They both say that MMO can restore power to old diesels. The rotary obviously isn't a diesel, but both their seals need to be in great condition and they both need to cover a lot of real estate.
on
Mobil 1 goes in my car.....
I have more fun than you.
on
Originally posted by rynberg
And how did it work out for ya? Inquiring minds want to know....
on
Originally posted by DavidDeco
What'd be interesting is then how well does KY Jelly work in the rotory
EDIT: BTW, I'm not sure whether to be surprised or disappointed that there wasn't any sexual innuendo until the 11th post -- way to go Rich!
on
I thought that the engine rebuilders preferred Vaseline.....
You've seen the movie Van Wilder? If not, rent it. When my princess and I used the yamalube, it was kinda like that scene where Van Wilder's Indian assistant buddy is romancing that fine girl and keeps slipping and sliding off her onto the floor....."Just once I would like to dine at an American pink taco stand"
rx8volks
Canadian Forum
08-11-15 10:30 PM
KAL797
Test Area 51
08-11-15 03:47 PM
