What is the function of the pilot bearing?
Old 09-28-03, 04:00 PM
Registered Piston Eater
The_7's Avatar
Question What is the function of the pilot bearing?
From searching I have found that it is a small needle bearing that is inserted into the end of the eshaft. I have also found that autos don't have them so I assume that it is clutch related. So what is its purpose? What happens when it goes bad? Thanks.
Old 09-28-03, 04:10 PM
Gregs's Avatar
it keeps the transmission input shaft spinning freely...
if it goes bad im assuming the trannt wont spin smoothly?
Old 09-28-03, 08:15 PM
I read your email
inittab's Avatar
It keeps the eccentric shaft and transmission shaft aligned.
Old 09-28-03, 08:53 PM
The_7's Avatar
why would a bad PB make it hard to put the tranny in first gear?
Old 09-28-03, 09:28 PM
Guackman's Avatar
I just changed my pilot bearing (and throwout bearing, cluth plate and pressure plate).
The pilot bearing sits in the shaft that the flywheel is attached to. It spins when your engine spins. Even when in neutral.
The pilot bearing is there because when you press on the clutch, the clutch plate stops spinning. The pressure plate and flywheel are still spinning but the clutch plate stops and so does the input shaft to your tranny (now the bearing is being used) and you can shift the car into gear. When you are not pressing the clutch everything is spinng together and so the bearing is not being used. This is why they always say to not hold your foot on the clutch at stop lights. Put it in neutral instead and release the clutch. If not you'll wear out the bearing prematurely.
If the pilot bearing goes bad, like mine did, the input shaft to your transmission will possibly still spin. Mine did because the bearing broke to pieces because in the end it was dry as a bone in there. i.e. no grease. It seized up the input shaft in the hole and so the input shaft was always spinning. Now I could never put the car in gear! I was stuck downtown and cannot shift into first. I had to shut the engine off at all the lights and fire it up when light went green. Finally got home. Dropped the tranny and changed everything. It now works like a charm.
Hope this explains it a little.
Ciao for now.
guackman
1985 GSl-SE (238,000 kms) (800 kms on new clutch)
Old 09-28-03, 09:30 PM
Guackman's Avatar
Forgot to tell you one thing.
When you change the pilot bearing, be sure to change the grease seal for it and put some grease in there.
I also changed the seals on the front and rear of my tranny while I had everything out. Cheap parts and you should change them now while it's taken apart. You do not want to get the tranny out that often.
Have fun.
Old 09-29-03, 04:20 AM
Inspector, Falcon Jet
rototiller1's Avatar
If the input shaft is sticking to the pilot bearing, when you push in the clutch to put it in first gear the input shaft will be turning, making it hard to go into gear.
Old 09-29-03, 10:35 AM
My FSP Fiesta eats Jettas
Wankelguy's Avatar
The pilot bearing supports the forward end of the transmission input shaft.
Old 09-29-03, 04:24 PM
The_7's Avatar
mine is hard to put in gear when the car is moving but not when stopped
Vartok
16
10-08-15 04:49 PM
Quick Reply: What is the function of the pilot bearing?
