how do I get rid of air in my coolant lines?
Old 10-08-03, 07:28 PM
donny's Avatar
I am still getting a "flushing" noise through my firewall ( passenger side ) when I start the car and sometimes when I just rev the motor at a stop. I am thinking there must be air trapped in the coolant lines that the AST is not removing..
Any other thoughts??
Coolant level appears to be full..
Old 10-08-03, 07:32 PM
don't race, don't need to
spurvo's Avatar
Are you checking the coolant level at the filler neck, NOT the overflow tank? The level should be low at the filler neck if you have air in the system, and it doesn't take much air at all to sound like a waterfall in the pass compartment (that's air moving through your heater core, BTW)
Old 10-08-03, 07:36 PM
donny's Avatar
Thats what I figured because the other day my water temp started to go sky high. I think it must have had an air lock.
How do I get the air out..???
Old 10-10-03, 11:28 AM
David Beale's Avatar
As stated elsewhere, you "burp" it out. Squeeze the rad. hose with the filler cap off. You should see some bubbles come out. Fill it to within 1-2" of the top. Run the car. When it cools off, do it again. It usually takes two to three tries to get it all out.
Old 10-10-03, 12:11 PM
Part out my Car
mmonaco's Avatar
easier way, just keep squeezing the top and lower rad hose and keep filling it with water till it wont take anymore! Than start er up
Old 10-10-03, 12:36 PM
Cihuuy's Avatar
u can also fill it from the Throttle Body (tb) lines as it is the highest point. another thing you can do is to change to a 1.3 pressure radiator cap if you havent.
Old 10-10-03, 12:42 PM
jpandes's Avatar
DO THIS:
1. Open the filler cap
2. Remove the coolant line at the back of the Trottle body
3. Pour in coolant while squeezing the rad. hose to force air bubbles out of the system and out the tb coolant hose.
>>With the Tb coolant line off, all air bubbles should rise to this point since it will then be the highest point in the system.
4. Start the car, warm it up for five minutes with the heater on full (to get bubbles out of the heater core)
The repeat steps 1 through 3
Your're done.
Old 12-09-03, 01:37 AM
8AN5H33
SWAT81's Avatar
would the air bubbles eventually be gone if you dont do this step? I hear it all the time now when I start my engine and highway driving. Also, sometimes I get the coolant refill light come on me, so I have to refill like a half a cup full. Obviously, I have a small leak somewhere? I'm confused. Oh and I did squeeze the top and bottom radiator hose while filling in to get rid of air bubbles.
Old 12-09-03, 01:20 PM
spurvo's Avatar
If you are getting persistant coolant loss and air in the system, even though you are contantly adding coolant to the filler neck, do the champaign bubble test. You may be in for a nasty surprise...
Old 12-09-03, 02:11 PM
pomanferrari's Avatar
Yeah, I second that. Start saving your money for a reman. I chased that air in coolant for a month then the terminal coolant buzzer went off. I was SOL by then.
Old 12-09-03, 02:58 PM
I'm curious to find out if there is any link between o-ring failure and the use of higher pressure caps. Has anyone ever heard anything about this.
Microtech
30
04-23-16 06:37 PM
Kyo
08-14-15 02:00 PM
Quick Reply: how do I get rid of air in my coolant lines?
