12A Turbo Distributor
Old 12-10-03, 03:47 PM
I can has a Hemi? Yes...
Directfreak's Avatar
Hey Guys,
I have some questions about the Jap Spec 12A Turbo.
Information is limited on it, but I need to know about the distributor.
As I understand, it's the ONLY Mazda OEM distributor that retards timing as well along with boost.
Can anyone give me some good clear pics of it, and
maybe the specs?
Do you set the timing like a regular dizzy?
Max Retard? Does it have a boost sensitive nipple?
Does it work well?
Any and all specific info you can provide will be great.
For now, I am switching to a blow through setup, while my Haltech goes back to AUS for repairs.
I plan on keeping the blow-through when I get a Series V convertible anyway (they are non-turbo in the U.S), so I want to know regardless of the Haltech
So I just want to know if this little distributor will keep my engine peppy, my timing dead on, and my engine from detonating.
Thanks!
Old 12-10-03, 03:59 PM
holley guy
mwatson184's Avatar
I think max retard is somewhere around 6 degree's, somebody needs to verify this. I read it a few days ago but can't remember where. I guess this is just a bump then, i'm interested as well.
-Marques
Old 12-10-03, 04:03 PM
I've read that as well, but some people on the other list are telling me it's 20 degrees. Which enough to run 15 PSI no problem, with niced advanced timing for off boost throttle repsonse.
Old 12-10-03, 04:24 PM
Rotorious7's Avatar
Thats the dizzy im running w/my Cartech Blow through
Old 12-10-03, 04:27 PM
Rotorious7's Avatar
Directfreak, were can i get a trailer like that
Old 12-10-03, 04:32 PM
Did you ever run your car with a stock Dizzy, and then the 12AT?
Did you notice a big difference?
Ot did you just buy the car like that?
Old 12-10-03, 04:46 PM
Rotorious7's Avatar
i bought the car like that, But after looking into it. I found it made a difference. The regular dizzy can be mod.. but limits tuning
Old 12-10-03, 07:42 PM
680RWHP12A's Avatar
5 degrees max and thats designed for the stock 12a turbo 6 psi of boost , no more ... best thing to do is weld a stock dizzy and run it at 5 deg. advanced
The1Sun
03-18-18 11:08 PM
Josh83rx7
09-02-15 05:57 PM
Joe428
16
08-19-15 06:24 PM
rx7brandon
08-16-15 10:55 AM
Quick Reply: 12A Turbo Distributor
