The fast way to change clutch?
Old 12-11-03, 01:21 AM
Little 7's Avatar
I wanna to get a new clutch by myself. I heard some people said the fast way is take out the motor to replace a new clutch.
Anyone do it by themselves. How long does it take? I need advise. Thanks
Does anyone have any web site show people how to replace a new clutch.
Old 12-11-03, 03:35 AM
duboisr's Avatar
MY mechanic pulls the transmission not the motor .He removes the flywheel to have it resurfaced, puts in new pilot bearing and rear main seal .How long a job? I do not know , but if he has a flywheel ready to put in ,it takes less than a day . He does not use air tools , so no gauled bolts . He made a tool to get the flywheel nut off with out an air impack .No air tools = slower ,but no bad threads or broken bolts
Old 12-11-03, 04:05 AM
LetsGO7's Avatar
I don't know....the mechanic has a LIFT which helps alot...he has room to play...if you don't mind about taking your motor out, then go for it....it takes longer but it's better than laying down on cold surface trying to get the flywheel nut off!
-joe
Old 12-11-03, 05:32 AM
I'm a CF and poop smith
skunks's Avatar
fastest way is to disconnect tranny
if you can get your car on a lift and get a tranny jack, it will go a lot faster
if i remember correctly, you first take off the brace thin under the car, then you just gotta take off cat and catback, then u just take off the ppf (6 bolts i think) and then dissconnect the drive shaft
take off the starter and unbolt tranny from engine, then disconnect tranny (still havent figured out how to do this part exactly there seems to be a couple of ways from sticking a screw driver in to tranny and prying on the release thingy or to pump clutch or something) and your done
Old 12-11-03, 09:23 AM
Schadenfreude...Ha Ha
wingsfan's Avatar
Dropping the tranny is far less work than pulling the motor. The worst thing is you might have to take the UIM off (I did because my arms wouldn't squeeze between the firewall and the UIM) to get to the top bolts on the tranny.
Anyhow, for detailed instructions Go here:
http://www.scuderiaciriani.com/rx7/clutch_install.html
That's exactly what I did to change my clutch. It took me a long time being my first time, as I went slowly and carefully.
Assuming you have all the tools you need you could do it over a weekend no problem. I'd guess the total time is somewhere between 10 and 20 hours of work.
Make sure you get the flywheel resurfaced, and you WILL NEED an impact wrench to get get the flywheel nut off, unless you're some freak of nature that can generate an insane amount of torque on a breaker bar.
If you decide to go through with it and you need either the socket (54 mm, mine is a 6 point socket) for taking the flywheel nut off, or the SST for the flywheel stop (to hold it in place while you break loose the evil flywheel nut), I have both of them that I no longer have need for that I will sell you for cheap if you're interested.
Old 12-11-03, 11:01 AM
Cheap Bastard
adam c's Avatar
It is not an easy job. If you don't have experienced help, and have not done this kind of work before, I suggest you pay a good mechanic to do it for you.
Old 12-11-03, 04:07 PM
Nomad Mod
Toadman's Avatar
Getting mine done today. Disc, PP, TO,Pilot, re-surface FW, seal, and rear main seal. Going with Redline M/T fluid while they're at it. I went with OEM parts which are not that bad(Daiken-made). An ACT/Centerforce would be awesome but is pretty stiff and grabby for stop/go traffic. Over $900 w/labor. Merry Xmas to me.
Old 12-11-03, 04:29 PM
rex u.k's Avatar
Go single turbo and its easier to pull the motor to do the clutch,if you're stock twins then drop the box.IMO.
Old 12-11-03, 04:34 PM
wingsfan's Avatar
I didn't find the ACT street/strip a problem at all in anything but reverse. After the 300 miloe breakin or so it was just like any other clutch. Those first 300 miles were damn grabby though.
Old 12-12-03, 07:47 PM
Nomad Mod
Toadman's Avatar
After 44k miles I went with the OEM because pedal pressure is a little lighter on my bad knee, even with hydraulic, that's all. So what is the correct break-in procedure? I've heard lots of advice: Don't slip it much, easy on the rpm, etc. whatever.
Centerforce has a disclaimer I found while searching:
"IT IS RECOMMENDED TO PROPERLY SEAT IN THE NEW PRESSURE PLATE & DISC ASSEMBLY TO ASSURE GOOD CLUTCH PERFORMANCE. CENTERFORCE RECOMMENDS 450-500 MILES OF IN TOWN STOP AND GO TYPE OF EASY DRIVING BEFORE APPLYING FULL POWER. IF YOUR DRIVING CONSISTS OF MAINLY HIGHWAY TYPE USE, THE BREAK IN PERIOD SHOULD BE LONGER THAN THE 450-500 MILES. IF THE BREAK IN PERIOD IS NOT PROPERLY FOLLOWED, CLUTCH LIFE AND PERFORMANCE CAN BE SACRIFICED."
Man, you should have seen the old one, it was purple-hued from overheating/slipping. Explains the crappy gas mileage lately also, even when no slipping is detected. Very grabby now, pedal engages at the bottom, like learning to drive a stick all over again sometimes. Rookie neck-snap starts, LOL!
Everyone else think this thread has good advice?
whinin
03-30-19 07:53 PM
TwentyDW
09-02-15 06:42 PM
Quick Reply: The fast way to change clutch?
