how to remove hail dings/dents from aluminum hood
Old 04-25-04, 02:34 AM
You've Been Punk'd
razorback's Avatar
ok i have a t2 aluminum hood that has a few hail dents. how would i remove these? i tried searching and i couldnt find anything.
Old 04-25-04, 02:47 AM
Lava Surfer
bingoboy's Avatar
paintless dent removal? unless i was a pro i don't think i'd trust myself to attempt pounding/tapping out aluminum.
Old 04-25-04, 02:50 AM
You've Been Punk'd
razorback's Avatar
they are not huge dings. its just bothersome i know alot of members has had this happen since aluminun dings so easily.
Old 04-25-04, 02:55 AM
FC3S_GTUs's Avatar
"Pops-a-dent" ....i saw it on an infomercial, search for that and see what comes up on your search
Old 04-25-04, 02:57 AM
FC3S_GTUs's Avatar
try this, it might or might not work, haven't used it before tho....
go here http://www.alltvstuff.com/pad1.html
Old 04-25-04, 03:00 AM
Speed_Machine's Avatar
your best bet is probably to just fill them and repaint your entire hood
Old 04-25-04, 03:11 AM
Exhaust leak
version13's Avatar
I bought that "ding king" kit from Schucks, and it works great. May take a few tries, but it works.
Old 04-25-04, 03:23 AM
You've Been Punk'd
razorback's Avatar
how much is it?
Old 04-25-04, 03:49 AM
Turbo Swamp Thing
RXSevenSymphonies's Avatar
Pops-A-Dent doesn't work, I've tried it. I've heard from numerous people that Ding King does work though.
Old 04-25-04, 10:09 AM
brohr01's Avatar
i know for steel you can lay a towel over the dent with some dry ice, the extream cold will pull the dent out. i do not know if this will work with alm.
Old 04-25-04, 10:38 AM
Icemark's Avatar
Originally posted by brohr01
[B]i know for steel you can lay a towel over the dent with some dry ice, the extream cold will pull the dent out.B]
And you have done this???
Old 04-25-04, 01:45 PM
I am back
George84's Avatar
Get a flat face body hammer and a dolly. Put the dolly on the back side of the dent and hammer softly around the dent. When hammering start from the outside and work your way into the center of the dent (in a circular motion). Make sure to hold the dolly in place.
Old 04-25-04, 02:12 PM
**-P I drive a miata.
nonameo's Avatar
www.autopia.org
those guys might be able to help you out...
Old 04-25-04, 02:41 PM
Exhaust leak
version13's Avatar
Originally posted by razorback
how much is it?
$19.99 I think, could be $29.99.
It already paid for itself though. I've popped out dents from my friends cars for about a buck a dent.
Old 04-25-04, 02:43 PM
Reverse Cerberus
evileagle's Avatar
I've done it on a few other cars, and for small/medium door dings it works pretty well.
Akaviri
09-09-15 03:56 PM
Quick Reply: how to remove hail dings/dents from aluminum hood
