any way to plug a pinhole in radiator hose?
Old 08-11-04, 07:19 AM
just dont care.
jacobcartmill's Avatar
i have a small hole in my upper radiator hose and it has developed into a tiny crack about 3mm long. i tried to use some JB kwik on the hole, but it lasted for a while and got brittle and fell off. is there anything i can use to plug this little hole? i cant get a new rad hose for 3-4 days and i have to drive in the heat until then.
Old 08-11-04, 07:23 AM
Green Flameless
WonkoTheSane's Avatar
duct tape True red-neck style
Old 08-11-04, 07:24 AM
Im Ron Burgandy..
rotoboy20's Avatar
Duct Tape!!!
Im Ron Burgandy..
rotoboy20's Avatar
Get Er Done!
Old 08-11-04, 07:33 AM
Green Flameless
That's funny, I don't care who you are...
Old 08-11-04, 07:35 AM
just dont care.
um yeah that doesnt work. ask me how i know
Old 08-11-04, 07:36 AM
Letting the Smoke Out!
Kingofl337's Avatar
try some JBweld see if that works.
Old 08-11-04, 07:47 AM
just dont care.
yeah...
Old 08-11-04, 07:52 AM
Dokta's Avatar
crack an egg open and drop it in the radiator. itll stop the leak once it gets warm... but im pretty sure its not good to have egg in your coolant system. its just an old trick if your coolant system springs a leak and you are sol in the middle of nowhere, you have to keep driving, and you just happen to have an egg on you.
Old 08-11-04, 07:56 AM
just dont care.
yeah i keep a dozen eggs in my passenger storage bin for a rainy day.
Old 08-11-04, 09:25 AM
WAYNE88N/A's Avatar
We use some special "tape" on aircraft that would help you, if you could find it at the auto parts store. Basically it's a rubber compound, and when stretched around something it will stick to itself so well that you'll have to cut it off when needed, it will not unwrap again, and will "swell" with the hose. The kinds I've used are orange colored with a small green stripe down the middle, or black stuff with a colored stripe (green, I think), it's about the width of electrical tape, and has a plastic "no-stick" backing that peels off as you're applying it. I've successfully used this stuff for blown radiator hoses in the past, and still keep some in all of my cars for emergencies. Wish I could give you a trade name, but if the auto parts place has it, the counter guy/girl should know what you want by my descriptions I gave if they have it...
If all else fails, clean up the area real good, and fill with black RTV liberally. Let it cure for at least 30 minutes before pressurizing the system. This might not work on the upper or heater hoses, then again, it might for the three days it needs to...
Old 08-11-04, 10:07 AM
just dont care.
i just used a tire patch (one of the 1" circle ones), that ones that you have to use the rubber adhesive compound (basically rubber cement) i figured that would be able to stretch/bend a little with the pressure in the hose.
Old 08-11-04, 10:20 AM
Eat, sleep, work, mod.
jon88se's Avatar
Spend $10.00, get a new hose!!
Old 08-11-04, 10:53 AM
WAYNE88N/A's Avatar
Lol, he will- in 3 days, he has to drive it until then (read the first post)
Old 08-11-04, 11:33 AM
Syonyk's Avatar
Go to the auto parts store, get a worm gear hose clamp, and clamp it on over the hole. This held for something like 6 months on my beater/parts hauler. Only reason it's not still holding is because the other hoses sprang leaks, I got sick of it, and replaced all the radiator hoses.
-=Russ=-
Old 08-11-04, 12:45 PM
just dont care.
i used that tire patch and the outer edge of the patches are thinner, so it ****** busted. i hate this ******* hose.
its not bad enough to make anything overheat, just enough to **** me off
Old 08-11-04, 12:51 PM
WAYNE88N/A's Avatar
And, as we all know, it doesn't take much to **** you off, lol...
Hell, even electrical tape will help a little, if it's just for 3 days (wrap it TIGHT)...
Old 08-11-04, 12:54 PM
just dont care.
ok i just put some gasketmaker (the right stuff, baby) and i'm gonna let it sit and then drive back to work. wish me luck
Old 08-11-04, 01:26 PM
DubbayoC's Avatar
if you have some plastic pipe laying around about the same size as the hose use a section of that and put a couple clamps on it.
Old 08-11-04, 08:57 PM
Natey's Avatar
Received 1,421 Likes on 735 Posts
Worked for MacGyver! I think he used only the whites, though.
Old 08-11-04, 09:09 PM
i am legendary
ddub's Avatar
Duct tape didnt work? I popped a hole at the drag strip, found some duct tape, wrapped it around about 10 times, drove home with no problem.
Old 08-11-04, 09:13 PM
I R SAD PANDA W/O BAW
ilike2eatricers's Avatar
Try some liquid gasket and then wrap it around with duct tape a couple times. I dont see how it couldnt work.
Old 08-11-04, 09:16 PM
Ring ading ading
Froggmann's Avatar
Just use duct tape. That will take care of it untill you get a replacement hose. If I remember right JB weld will just eat the hose.
Old 08-11-04, 09:20 PM
i am legendary
ddub's Avatar
Yah, like silicone. I forgot about that, that's what I used another time too. Put a bunch of silicone on over the hole/crack, let it fully dry, then wrapped in duct tape and it worked really well.
Old 08-11-04, 09:24 PM
inflatablepets's Avatar
There's a silicone tape that would work on that. I think Wal-mart sells it.
Quick Reply: any way to plug a pinhole in radiator hose?
