rusty spark plugs?
Old 10-25-04, 04:12 AM
joe3180's Avatar
Question rusty spark plugs?
anyone know what would cause spark plugs to rust? i just pulled mine out and they were wet with gas and rusty....and i have not drivin the car. i just bought it a few days ago with a maybe dead motor. any ideas? tomarrow morning im compression testin it. thanx for any help.
Old 10-25-04, 04:44 AM
...94% correct.
Makenzie71's Avatar
We need more details. Has the engine/car sat for a while? does it run now? Stuff like that. Rust is caused by oxidation....a material can oxadize in any enviroment for a number of reasons. It's the least of your worries.
Old 10-25-04, 05:08 AM
RETed's Avatar
GET NEW SPARK PLUGS
Over the next several weeks, check the spark plugs at least once a week.
If it's gets rusty, it's bad news.
If they don't get rust, breathe a sigh of relief.
-Ted
Old 10-25-04, 07:36 AM
Mountain Rotary Mod
Parastie's Avatar
Originally Posted by RETed
GET NEW SPARK PLUGS
-Ted
I'm with Ted, if new sparkplugs start to rust then you could be in trouble. Rust is usually caused by moisture and if the plugs are rusting then there's moisture in the combustion chamber which is VERY bad.
Old 10-25-04, 01:28 PM
rs_1101's Avatar
there is a difference between dirty plugs and rusty plugs right? with my last set, i cleaned them off with a brass brush, and the metal still wasnt shiny like is supposed to be.
Old 10-25-04, 01:30 PM
Jesus is the Messiah
Tofuball's Avatar
If the PLUGS are rusty, I'd worry about the ROTOR. It would rust before the plugs, IMHO (o)_(o)
Old 10-25-04, 02:39 PM
Daily Domestic Killer
BlackRx7's Avatar
They will also rust if your plug wires/boots are in bad condition and your motor got wet on that side, if it runs without smoke and smell of antifreeze then you should be okay, just get a new set of plugs and wires, usally aways a good idea when buying a used Rex
Old 10-25-04, 03:36 PM
joe3180's Avatar
well i changed the plug but i dont think that will do any good cuz i just finished the compression test....0 and 30. so im guessin dead motor. oh well. i was going to put a new one in anyway. this just kinda shows i gotta now. oh and the car was sittin around for over 5 months. so now is the question...rebuild or new motor all together?
Old 10-25-04, 04:49 PM
rs_1101's Avatar
you did do the test the right way right? remove check valve and whatnot?
i take it the car wont start either?
Old 10-25-04, 04:50 PM
Mountain Rotary Mod
Parastie's Avatar
I'd go rebuild, but i'm an adventures person
Old 10-25-04, 05:26 PM
joe3180's Avatar
car wont start worth a damn but i know its gettin fuel....i can smell that one. not sure bout the spark but i did put new plugs. and the compression test shows nothing so im guessin that it. well i didnt remove the valve but i did leave the push button pushed in. you think that would be the reason? i followed the instrutions on the website.... www.rotaryresurrection.com
Old 10-25-04, 06:44 PM
90 Turbo
amishboy's Avatar
water
Old 10-25-04, 09:08 PM
joe3180's Avatar
oh i mean....do you think cuz i didnt rip out the internals of the compression tester it didnt come out right? cuz i held on to the pressure release valve so i could see it bounce and all.
Old 10-25-04, 09:10 PM
Tofuball's Avatar
Dude, if there is rust inside the motor, I SERIOUSLY doubt you can rebiuld it.
The internals are probably trashed.
Old 10-25-04, 09:33 PM
90 Turbo
amishboy's Avatar
New motor the rotor with 0 compression is bad. Check the junk yards and there may still be some good parts in the one with 30 take it apart and sell it .
Old 10-26-04, 01:25 AM
joe3180's Avatar
u think someone would take the motor as a core? but yea i think ill part it out. i mean i kinda wanna see what it looks like inside after what i saw. lol. if i do take it apart ill be sure to post the pictures....im sure they will be worth a laugh or two.
Old 10-26-04, 01:38 AM
RotaryResurrection's Avatar
Your internals probably look like this:
Old 10-26-04, 04:18 AM
joe3180's Avatar
i bet it does.....poor me. ok now im the guy that emailed you before....not that you would remember me exactly but....would you take something like that as a core?
Old 10-26-04, 08:32 AM
Tofuball's Avatar
Ouch.
Old 10-26-04, 08:39 AM
Mountain Rotary Mod
Parastie's Avatar
Man, leave it to kevin to make us rotor heads sick....
Old 10-26-04, 10:37 AM
Engine, Not Motor
Aaron Cake's Avatar
It's still good, it's still good! Just hit her with the old sand blaster, rinse her off, and put her back together.
(My useless post for the month)
Old 10-26-04, 10:44 AM
Seduced by the DARK SIDE
SureShot's Avatar
I still will make a nice clock stand.
Old 10-26-04, 12:00 PM
To do what with?
Old 10-26-04, 12:14 PM
Eat, sleep, work, mod.
jon88se's Avatar
To do what with?
Makes a very functional paper weight
Old 10-26-04, 12:32 PM
Sure, if you dont mind dirty paper...
Quick Reply: rusty spark plugs?
