Engine bogs @ 3,500 RPM?
Old 12-03-01, 01:07 PM
Carter's Avatar
Under light throttle load, the engine seems to bog near 3,500 RPM. It seems the engine will bog at the same RPM point every time, so I can't think of it as being user induced. Any suggestions?
Old 12-03-01, 01:11 PM
Flavour's Avatar
sounds like the infamous 3800rpm hesitation problem. Unfortunately i have no idea how to fix it but i remember reading about it somewhere on the net, try searching for 2nd gen faqs ont he internet, if i remember where i saw the document, i'll let you know
Old 12-03-01, 01:14 PM
Carter's Avatar
Jeeze... Does anyone have the number to a good witch doctor to remove the voodoo curse on my car?
Old 12-03-01, 01:25 PM
NathanRX7's Avatar
You need to add some more gounds. If I remember correctly, your ECU is not getting a good ground. You can run a new ground directly to the ECU, but I bet it would fix it if you just ran a couple 4 guage ground wires from the batter to the chassis and to the engine. I also grounded my exhaust at the y-pipe to my transmission. With a multimeter, I now have 0 resistance between any 2 points on my car.
NCsublime's Avatar
Only cure I've heard of is a grounding strap and a lot of grounding. Good luck.
Derek
Old 12-03-01, 02:14 PM
mazdaspeed 3 coming soon
hondah8er's Avatar
I had the same problem with my t2 motor in my 1st gen. Ran another ground and nothing (back in the summer). I will bet it is your TPS. it's not adjusted properly
Old 12-03-01, 03:24 PM
Seduced by the DARK SIDE
SureShot's Avatar
I presume you have an NA. Check the thread further down "Dyno Chart" by Mallard Duck. That notch at 3800 is normal as the secondary ports open. If yours is worse the grounding mentioned earlier may be needed.
Old 12-03-01, 11:05 PM
Carter's Avatar
Thanks for the help; I'll give the extra ground straps a try.
SureShot, I've got an '87 T2.
Kyo
04-13-19 09:24 AM
Th0m4s
02-26-19 02:04 AM
C. Ludwig
01-30-19 06:31 AM
CaptainKRM
14
08-26-15 09:52 PM
Microtech
08-23-15 11:04 AM
Quick Reply: Engine bogs @ 3,500 RPM?
