Hawk HP+ vs Hawk HPS vs EBC Greenstuff vs Bonez stage I
Old 01-31-05, 08:54 PM
enigma662's Avatar
Should be helpful to anyone replacing brake pads. Anyone use these types? Opinions?
Old 01-31-05, 09:06 PM
rynberg's Avatar
If you can live with the dusting and occasional squealing under light braking, the Hawk HP+ are extremely grippy and durable pads. They hold up well under track use (they do fade but they don't FAIL, unlike the HPS). The HPS are OK for street driving but I have come to love the high friction coefficient of the HP+. I have heard both bad and good regarding the EBCs....mostly bad. I've heard decent things about the Bonez Type I pads, but they will fail under track driving conditions like the Hawk HPS (which they might be rebadged HPS anyway!).
Old 01-31-05, 09:09 PM
12th son of the lama
legal-z's Avatar
i lived by ebc's on my older datsuns. then i put a set on my fd and they sucked! they basically fell apart with about half the pad left. the hawk hp+ i replaced them with seem to be much better imo.
Old 01-31-05, 09:34 PM
Living the dream...
93silverbullet's Avatar
I agree with Rynberg , I currently Hawk HPS on my FD, but since I don't track my car (yet) they're fine. Very little dusting and much better than stock pads IMO.
Old 01-31-05, 10:32 PM
omgwtfposlol
particleeffect's Avatar
street? track? EBC-green are supposed to be great STREET pads, which is why i have them here ready to go on.
Old 02-01-05, 07:10 AM
r71's daddy
David88vert's Avatar
I usually run HP+, they are an excellent pad. The Blacks are what I use for th etrack, they eat rotors VERY quickly, so they are not a good street pad. I recently put the EBC reds on my FD, so far they are a good street pad. I have not tried the Reds in a semi-race setting yet. Haven't had them on long enough to determine pad life either.
I would avoid HPS and Greens as I am sure that they would not hold up to my driving.
BTW - the lighter the car, the less abrasive of a pad you need.
Old 02-01-05, 08:31 AM
keynote22's Avatar
Hawk hp vs hps is that the same as blue and black? I see that they are different part numbers...but i wonder Radkins used blue for a long time and felt they were good for the road but tended to fade a bit after several track laps. He switched to blacks which were great for the track but squeak like a **** on the street...Im mean like really really bad. In the end he switches from blues to black at the track.
I use ebc green stuff. They are fine for the street. Low dust no noise. On the track they are vastly superior to stockers in life span (length of time to heat up) but once they heat up I dont like the way they feel. They are not really track pads and feel vague as they get hotter. The stock pads were actually had a better "feel." At least you knew when they were giving out. It was an all or nothing sort of thing. The green stuff just sort of gets to the point where you cant tell what they are doing. In the end I like them better than than the stockers as I get more laps. it would be a tough call to choose between these and hawk blues as I dont track very much (3 times a year) If I was tracking more I would not use the greens. Since Im mostly on the street, greens are fine.
Tire rack told me that the greens are suitable for light track and the reds are not suitable for the street. I called ebc to get the answer as the descriptions are not so good.("Greens for light track use" I think it says) They weren't much help. I will probably go with the reds when these give out. Many people complain that the greens burn away really fast on the track. I have not noticed that but then again I am not an aggressive braker on the track. Im still very newb on track driving. I have also heard that they fall apart at 1/2 pd thickness but have not seen that yet. Then again, like I said I dont hammer my brakes.
Old 02-01-05, 10:23 AM
rynberg's Avatar
Um....no. The blue and black pads are true racing pads and are just simply DANGEROUS to drive on the street -- with much less braking force than any typical street or street/track pad at street temps. Either of those pads would also eat through a rotor in short order in street-type driving.
And unless Radkins was running full out for many laps on a very brake-abusive track, I seriously doubt he got a set of blues to fade.....
Old 02-01-05, 10:29 AM
DamonB's Avatar
I've been through a few sets of HP+ and like them other than the dust and squeaking. They're fine except for real track running; forget about it if you have R compound tires. I could only run 2 hard laps before fading them on R tires. They don't give up completely even then but the pedal pressure goes way up and you start eating them at that point.
I have a set of Porterfield R4-S waiting to go on right now, we'll see what I think of those. They're much more expensive so I had better like them
Old 02-01-05, 01:30 PM
keynote22's Avatar
Just an observation that many companies tend to use the top consumer brand as the bottom commercial brand. I really had no idea.
You must know him He usually goes through a set of rotors every few events depending on the track. He uses blacks in the back and blue in front, changing brake fluid after every event. It was the blacks that faded not the blues..had that wrong ways around
Old 02-04-05, 10:05 AM
Rx7 Wagon
Narfle's Avatar
the hp+'s destroyed my stock fd rotors...meh it was itme to upgrade anyways
Old 02-07-05, 01:17 PM
NC_FC3S's Avatar
I'm not sure if you have a FC or FD, but I had the HP+ on my vert and though I loved the grip , I really hated the mess they made of my rims. I had actually ordered the HPS pads as replacements for the stock pads from a dealer in SC, but they sent me the HP+ instead. The guy told me I'd like them better, so having not used the forum here at the time I went ahead and put them on. Since my vert is just a daily driver (rightfully so) , I never probably saw the full benefit of these pads. I got sick of constantly cleaning the wheels and switched to Bendix pads. I can tell they don't bite as much as the Hawks, but I can live with that considering it still stops well. I guess the real question is the type of driving you'll do.
Old 02-08-05, 07:42 AM
Missin' my FD
pianoprodigy's Avatar
So you Vert guys would recommend the EBC Greens as a nice step-up from the stock pads (for a 90 Vert)? I'm not looking for race-track performance, but just something better than the stock pads. I want NO noise and LOW to NO dust.
Old 02-10-05, 01:12 PM
Is that thing a Miata?
Echoratz's Avatar
I have ebc greens, they dust like a bitch but are silent.
Old 02-10-05, 01:32 PM
I am back
George84's Avatar
I have the Hawk HP+ pads on my vert, they put out a **** load of dust and make a little noise from time to time. Over all the dust is the only think I don't like but it is worth dealing with because I never knew that my brakes could work this good, I like them.
~George
Old 02-10-05, 01:42 PM
I am back
George84's Avatar
Go to Mazda and order stock pads if you want no noise and low dust.
Old 02-10-05, 02:27 PM
Speed Mach Go Go Go
GoRacer's Avatar
Geen EBC's suck *** covered donkey dong! They chewed up my rotors and I turned them three times before I threw the poop in the trash where they belong. The Hawk street work great. I have no reason for the + untill I can hit the track. I don't use any pads that have metalic crap in them.
Old 02-10-05, 02:40 PM
diabolical1's Avatar
i use the HP+ on my car and they are great! they do squeal and it irks me every once in a while, but for the performance they give, it's a very small price. dusting has never bothered me, so that's not an issue. i can't wait until i can get the HP+ for the rears.
Old 02-10-05, 07:42 PM
2a+RoN's Avatar
My MR2 buddy just ordered a set of those and I'm very curious to see how they do...
Old 02-14-05, 01:33 AM
gnx7's Avatar
EBC Greens will dust less and have less initial bite..... HP+ will bite harder and create more dust. If you drive hard.... get the HP+ pads... If you are fairly aggressive the EBC Greens will work great.
Rinse your wheels every morning and they should be fine with HP+'s.... but be prepared to spend some time on them when washing the car if you are running a "mesh" style wheel. Toothbrush time and Eagle One wheel cleaner (with acid, wear gloves and watch out for your eyes).
-Mark
LongDuck
10-07-15 08:12 PM
lnlreaper
09-27-15 09:59 AM
Quick Reply: Hawk HP+ vs Hawk HPS vs EBC Greenstuff vs Bonez stage I
