Best brand o2 sensor to get ? Ngk , Bosch , etc ?
Old 03-22-05, 09:15 PM
Rotary Power
wthdidusay82's Avatar
I need to get an oxygen sensor for my rebuild, i figured i might as well...
Think ill prolly go with the ngk, although some sites have been misleading about the applications it has ... NGK part# 24006 , sparkplugs.com lists it as not being used in RX7s , while at ngk.com it does (this is where i got the part #)...strange.
whered everyone get their o2 sensor and what brand..
Old 03-22-05, 09:25 PM
Haven't we ALL heard this
Wankel7's Avatar
Get the cheapest sensor you can ..... it really dosen't mater. It is JUST a single wire o2 sensor.
Might even find a bosch box has an NTK sensor (Which is built by NGK)
James
hyperdemon's Avatar
I just bought a bosch, but I haven't put it in yet... I think my current o2 sensor has been toast since I bought the vehicle, so it'll be interesting to see the difference a new one makes.
Old 03-22-05, 11:38 PM
Nurse I need 1300cc's NOW
alwayssideways's Avatar
i bought a universal bosch for like 17 bucks from Advance Auto. Works fine for me
Old 03-22-05, 11:47 PM
Mint87RX7's Avatar
i got the bosch for $14 at autozone
Old 03-22-05, 11:50 PM
7th Heaven
slpin's Avatar
James
took the words out of my mouth!
Old 03-23-05, 05:35 AM
felixwankel88's Avatar
i would go with a bosch i have a new one waiting in the garage for me
Old 03-23-05, 05:51 AM
I live in an igloo
BlaCkPlaGUE's Avatar
I bought the bosch, because I asked for an O2 sensor, he ordered it in, and when I got it, it was bosch.
I payed 60$ for mine... 14$ wtf? I got shafted..
Old 03-23-05, 06:14 AM
Rotary Power
James
The NGK isnt any better ? I mean i'll pay the extra $$ for the ngk if its better quality, both of my cars had NGK o2 sensors when taken out... I found one online for $35.00 , found another at rx7.com with oem connector for 40.00$ , to me id rather have the best i can get.....im not too fond of the bosch stuff, i myself would think ngk is better....and that you usually get what you pay for
Old 03-23-05, 12:10 PM
Jesus is the Messiah
Tofuball's Avatar
You all got shafted, Olympic sells the Bosch one for $7
Mine are more expensive, now that I have to buy the $32 VW wideband :O
Old 03-23-05, 12:39 PM
Mountain Rotary Mod
Parastie's Avatar
No, for the stock O2 sensor it doesn't make a difference. The readout on the single wire is just for the ECU's basic balance of A/F ratio and doesn't need to be extremely accurate. The ECU pretty much only read 3 settings. Rich, Lean, and Stoich. I doesn't really calculate how righ, or how lean.
Old 03-24-05, 12:44 PM
Rotary Power
there anything better u can get than stock...like a wideband o2 sensor ? or do u need a bunch of stuff to run a wideband o2 ?
Old 03-24-05, 01:32 PM
Mountain Rotary Mod
Parastie's Avatar
Reading is one of those skills you didn't pick up did you?
A wideband O2 sensor is only needed to properly tune the engine.
You do not NEED anything better then a cheap bosche for the stock setup or any other setup that used a closed loop A/F system.
A wideband O2 sensor requires more electronics to work that will cost you nearly $400 new.
So let me say it once more for those in the back.
YOU DO NOT NEED AN EXPENSIVE O2 SENSOR FOR ANYTHING THAT IS NOT A WIDEBAND O2 GUAGE, MONITOR, DATALOGGER. If you're just running stock and do not need to tune an aftermarket ECU then you do not need a wideband system.
Old 03-24-05, 02:20 PM
Snrub's Avatar
So there's an NTK (by NGK - says so on the box) and an NGK? Calling around locally the Bosch unit costs ~$60CDN and the NTK can be had for ~$45CDN. I hate you bastards who are getting them for $14US!
Old 03-24-05, 02:26 PM
Rotary Power
but for using an safcII or something like that you would want a wideband o2 ? would you be constantly running with wideband o2 or would u switch back to closed loop o2 sensor after tuning with wideband
Old 03-24-05, 03:41 PM
Wankel7's Avatar
When you run a wideband sensor/controler/display you normally install it in a new bung in the exhaust system.
Leaving the stock sensor untouched.
James
Old 03-24-05, 03:54 PM
Mint87RX7's Avatar
^That I did not know
Old 03-24-05, 03:59 PM
Mountain Rotary Mod
Parastie's Avatar
The more expensive Wideband sensor are more susceptible to heat, which is why you mount them lower on the downpipe, but in front of a Cat (if you have one). If you place it in the stock location it'll burn up and you'll be out $60.
Old 12-01-06, 02:51 PM
ROTARYROCKET7's Avatar
i jsut found it on summit racing
http://store.summitracing.com/partde...5&autoview=sku
NGK o2 sensor made by NTK
Old 12-01-06, 08:36 PM
Newbie
my87fc3s's Avatar
http://www.diyautotune.com/catalog/i...nsor-p-41.html
this is the one i got, im not plannin on goin cheap for my car. . it's my baby, works really well to i might add
Old 12-03-06, 10:02 PM
Just found out there for Friggin FD's
Universal No
Make MAZDA
Model RX-7
Engine Type R2
Engine Size 1.3L/1308cc
Liter 1.3
CC 1308
Beginning Year 1993
Ending Year 1995
Engine Family Mazda Rotary series, R2 engine type
Oxygen Sensor Location Front
Found the right one
Universal No
Make MAZDA
Model RX-7
Engine Type R2
Liter 1.3
CC 1308
Beginning Year 1987
Ending Year 1988
Jason NYC
Old 12-04-06, 12:56 AM
What's the point??
papiogxl's Avatar
Been there, done that. This man speaks truth lol.
