New mustang wheels on FD's
Old 04-12-05, 03:11 PM
Lets Go Hokies!
afterburn27's Avatar
I was doing some searching on wheels and it appears that the new mustang ('05+) wheels have a 5x114.3 bolt pattern with a +45mm offset. So keep an eye out for aftermarket mustang wheels (I think all the stock ones look like poo, at least on our cars). I am hoping they come out with a cobra R style wheel in the +45mm offset, I think it would look nice on an fd. Just a heads up...
Old 04-12-05, 03:20 PM
Power Trippin'
SpeedKing's Avatar
These? Heresy!
Personally, I wouldn't put them on, but they're not bad looking. Remind me of SSR Integrals w/ a Cobra centercap. Do you know what they weigh?
Old 04-12-05, 03:29 PM
Lets Go Hokies!
I don't know how much they weigh, but I remember hearing that they are fairly light.
There are also a lot of replica wheels in the mustang world... some crap, some not.
Old 04-12-05, 06:29 PM
Lookie Only
POM HB's Avatar
Have you guys seen the Mustang GT-R (I saw in R&T mag last month) 's wheels? Multi peices. Look nice and I like it a lot.
Old 06-30-05, 04:17 PM
Lets Go Hokies!
Out of curiousity I have been keeping an eye on mustang wheels. I spotted these on www.discounttiredirect.com for $154 each:
Everything looked nice, 17x9, 5x114.3, +45mm, affordable... then I emailed about the weight... 26.0lb!! ouch. No wonder they are so cheap.
The search continues...
And for those that don't think this style of wheel looks nice on an FD, check out negative's old car:
Old 06-30-05, 05:23 PM
evalutionr's Avatar
wheels look ok,i know i wouldn't put them on, they do look kinda like ssr. i think the weight might be a slight heavy not sure
Old 06-30-05, 05:25 PM
BlackRX7Turbo's Avatar
the ones you saw from discounttiredirect are 4 lug anyway...
Old 06-30-05, 07:01 PM
Lets Go Hokies!
They just use the same pic for all sizes of that wheel. They do have 5x114.3 bolt pattern with a +45mm offset.
Old 07-01-05, 05:12 AM
-=\V/an\G/ota=-
VanGota's Avatar
wheel
well for one thing the cobra weighs about 3x more then the FD and not only that the wheels will be too heavy because their about 1-2 inches wider USALLY but they put a heavier wheel on mustangs because mustangs handle like crap! they do if they have a light front end bcuz i mean if you have a light front end and much power in the rear with a rear wheel drive i mean the back end of a mustang weighs more then the front their not like mazda's they do not have 50-50 weight or as incase of a rx7 51-49 (rx8 has 50 50) so i mean they look ugly in the first place on an rx-7 not only that they are probally too wide. if not i still think they wouldnt be good (putting american brand on a import... just not my kinda thing!
-van
Old 07-02-05, 05:14 PM
LeavingRX7/TwinTurboStang
thefunksyourbrother's Avatar
www.jegs.com
5 star Cobra wheel. 5 lug
17x 9.5 f $146.99
17x10.5r $166.99
http://www.jegs.com/cgi-bin/ncommerc...61&cgrfnbr=831
Old 07-02-05, 09:22 PM
Slower Traffic Keep Right
poss's Avatar
-van
Did you eat paint chips as a child?
Old 07-02-05, 10:24 PM
Avoid the Noid
travisorus rex's Avatar
I want one.
Old 07-04-05, 02:11 PM
Former Rx7 *****
Cheers!'s Avatar
For the street, who really cares? if you bend it or flat spot it on a big *** pothole your heavy wheels won't make your wallet ultralight weight when you need to go get a replacement.
Old 07-04-05, 02:13 PM
rynberg's Avatar
40+ more pounds of unsprung weight is definitely noticeable, even on the street. But hey, a lot of owners only care about looks.
Old 07-06-05, 01:42 AM
gnx7's Avatar
Van- you must be on crack. Not one thing you said made sense or was even correct. Someone make this guy a moderator
Old 01-02-08, 03:36 PM
M104-AMG's Avatar
I read that the center bore (CB) is 70.3 on the Mustang, and only 67.1 for the FD RX7.
As such, 2005+ Mustang wheels will not be "hub centric", and have the possibility of extreme vibrations at speed.
Can someone please confirm ?
Thanks,
:-) neil
Old 01-03-08, 11:09 AM
Big Snail
93FD3S's Avatar
^ That is true in some cases that I've seen. I personally wouldn't install them without the proper hub centric rings. Check with your local wheel and tire shops for the rings.
Old 01-03-08, 12:01 PM
owen is fat's Avatar
real deal OEM ford wheels are lighter than the cheap replicas.
they dont look too bad on an FD.
Old 01-03-08, 01:31 PM
Lets Go Hokies!
Thanks,
:-) neil
wow, old thread. haha
I would suggest either buying or machining some hub-centric rings, just like you do for any aftermarket wheel.
However, I really feel that hub-centric rings are pretty unnecessary. The lug nuts should keep the wheel centered just fine. It's not like the hub-centric rings fit tightly over the hub anyway... I have plenty of friends who run aftermarket wheels without the rings on the street and on the track without problems.
But I use them anyway because they are so cheap. lol why not
09-16-18 07:16 PM
rx7jocke
72
06-17-16 03:48 AM
dillrx7
09-07-15 09:38 AM
Quick Reply: New mustang wheels on FD's
