warning buzzer - what is it
Old 04-24-05, 07:56 PM
Newbie
bakerb955's Avatar
Just pulled my RX-7 1984 out of winter storage, put in new battery; started right up.
Problem: a warning buzzer is going off all the time - its pretty loud and is impossible to stay in the driver seat.
Warmed it up but no change.
What is it and how do I fix it?
bakerb955
Old 04-24-05, 07:58 PM
1985 RX7 GS
xxshatteredsoul's Avatar
Could it be the buzzer for the seatbelt by any chance? That thing is annoying and loud.
Old 04-24-05, 08:04 PM
Webber Powered
nigel20b's Avatar
it can be your door light buzzer mine were buzzing for long time until my friend solve that problem
Old 04-24-05, 08:35 PM
My Money Pits
Goldfinger's Avatar
My 85 GSL goes through a similar scenario when stored for an extended period. In my case, the engine over-rev buzzer will come on when I crank it up. Usually, it goes off after the engine warms up and/or after it has been driven a couple of times within a frequent time period. I think the electrical connections in the later FB's are sensitive to inactivity but tend to perform well with use.
Old 04-24-05, 08:46 PM
Kentetsu's Avatar
Short term fix;
Look down in front of the battery for a little black box bolted to the front wall. It will have a plug going into the bottom of it. Pull the plug and the noise should stop.
Did you by any chance clean the engine bay recently? This happens to mine whenever it gets wet...
Old 04-24-05, 11:10 PM
Replaced the Displacement
pimpncuba's Avatar
thats weird. i don't have a buzzer for door ajar or seatbelt. but the rev buzzer works just fine
Old 04-24-05, 11:21 PM
Turbo widebody FB
Dan_s_young's Avatar
Make sure you have enough coolant, theres a loud buzzer if your running low...
Old 04-25-05, 04:18 AM
Kentetsu's Avatar
Buzzer
Yeah, but he didn't mention that he had an idiot light on his dash for low coolant level.
If you pull the plug on the oscillator as I said above, you will still have the dash lights to warn you of an issue, but you won't have the alarm. Mine does this whenever I clean the engine bay. I don't think it's the oscillator itself, but rather one of the sensors or a connection that gets wet. It sometimes happens in wet weather too. Now I just leave it unplugged all the time without any issues. Hope this helps...
Old 05-01-05, 04:44 PM
Newbie
bakerb955's Avatar
Thanks for the information and advice. I did what you recommended plugged the oscillator and now its drivable again.
Old 05-01-05, 05:42 PM
Right near Malloy
Pele's Avatar
Location: Behind a workbench, repairing FC Electronics.
It's funny. I've NEVER seen a 1st gen that had a buzzer for low coolant, oil level, oil pressure, or otherwise... I think the oscilators are prone to going bad.
Seatbelt/Door open with key in works fine and Over-Rev DEFINATELY works here.
Old 05-01-05, 07:17 PM
Tha ladies man
BuffDaddy915's Avatar
My uncle had a buzzer go off with a constant buzzing. He took the car to Mazdatrix mechanics and ended up being some kind of warning to get a tune-up. Apperently after so many miles or something like that. Might be it?
Old 05-01-05, 11:11 PM
LA FIEBRE
d. quinones's Avatar
I get that buzzer whenever is cold and the car is cold also, but
like Goldfinger said, it will go away after the engine warms up.
Old 05-01-05, 11:40 PM
Turbo widebody FB
Wow I really didn't know our cars had something like this... Can someone confirm this?
Old 05-01-05, 11:58 PM
Bluntman
riza's Avatar
^^^ sounds like BS to me. Just trtyin to play the fool and cop some cash for an unecessary tune-up
Old 05-02-05, 12:06 AM
Keegan's Avatar
i need help
Old 05-02-05, 12:26 AM
Turbo widebody FB
Originally Posted by Keegan
i need help
LOL wtf?
Old 07-25-05, 09:00 PM
BigDogIT's Avatar
Is this thread dead? Because I have the same problem and i can't figure it out. I pulled the oscillator, what was in the place everyone directed me to anyway and the problem did not go away. I there any other component that can cause this buzzer to go apeshit like this?
Old 07-26-05, 06:44 AM
MIVEK's are for wannabe's
Pen_Two's Avatar
My loud obnoxious buzzer I had going off was the idiot light for the exhaust. I haven't started it since then because my header fell apart when I tried to remove the cats. So, I guess my problem is fixed. Lol.
I never did get around to putting that RB exhaust on.
I can't wait to try and take that header off.
Old 07-28-05, 03:18 AM
1983 GSL, 1987 323 "GX"
jays83gsl's Avatar
Hmmm, I guess I'm fortunate in the fact that the original owner removed ALL the buzzers from my car. . . .
The1Sun
09-18-15 07:13 PM
The1Sun
09-15-15 04:45 PM
86glxNA
09-15-15 04:20 PM
Quick Reply: warning buzzer - what is it
