Will a Little STARTING FLUID sprayed in the airbox...
Old 05-02-05, 03:36 PM
harley71105's Avatar
I occaisionally have to "assist" my 88 S4 on start up....will Ether if used sparingly do any harm to a Rotary Engine....I could not find any info in "Search" and as usual Thanks !
Old 05-02-05, 03:40 PM
HAILERS
HAILERS's Avatar
I've used it in the past with NO harmful experiences. I usually spray for about one to two seconds, thats all it takes. NEVER use it to keep a engine running though. To see why, just spray it into your lawnmower while its running. Knock, knock, knockity.
Old 05-02-05, 03:42 PM
Cool....and thanks Hailers.......you always are a big help
Old 05-02-05, 05:56 PM
rcjunkie's Avatar
Occasional ether use will not harm your engine. Ether has gotten a bad rap for many reasons but its rap is mainly form use in diesel engines where it can cause glow plugs to swell (can't remove them) and shooting a flammable fluid into a diesel engine (which has no throttle body) can cause a runaway engine.
Try to buy a starting fluid that contains an "upper cylinder lubricant". Pure ether doesn't have any lubricating qualities and can wash away any oil film in your engine's internals.
Andy
PS Be careful, a stray spark or flame when spraying this stuff can cause an interesting fireball. I use ether to start my snowblower and had an interesting mini-explosion from a carb backfire. It was loud and almost cost me my eyebrows.
PSS The use of ether is indicative of a problem with your engine and you should have the affected system checked and repaired.
Old 05-02-05, 08:55 PM
I've done it on occasion after my '88 NA SE sat for 6 months with no fuel in the tank & a dead battery. Make sure U have fuel in the tank & use sparingly. I have found it doesn't help with a flooded engine. Install a fuel pump cutoff switch if U are flooding out.
Ramses666
sherff
09-12-15 12:22 PM
rx7shirley
09-02-15 02:11 PM
Quick Reply: Will a Little STARTING FLUID sprayed in the airbox...
