firing order
Old 05-19-06, 01:31 PM
Newbie
chris7695's Avatar
Question firing order
hay can any one help i have a 85 rx7 and i cant get it to start i know its getting fuel, has new plugs, and wires, i know the distributor is good but i can only get one cylinder to fire so it must be out of time but i can only get the timing light to light on the one plug. i need to know what the firing order is the guy at the store said it was 1212 but what does that mean. i have it set on the top dead center mark but it wont even backfire. i need to know which 2 wires go to the coils and where the other 4 goes this t1, t, l1, l, l2, t2 stuff is wierd to me never had anything with a rotary engine in it. can any one help....
Old 05-19-06, 01:39 PM
Super Moderator
gsl-se addict's Avatar
The bottom plugs are leading (L), the top are trailing (T). Looking at the engine, it should be:
T1 T2
L1 L2
The front housing is 1, the rear is 2. For the coils (black cylinders near battery), the one closest to the front of the car is trailing (T) and the other is leading (L). The wires should go from the coils to the distributor cap without crossing. Good luck. Welcome to the forums.
Kent
Old 05-19-06, 02:02 PM
Too old to act my age
Rogue_Wulff's Avatar
Also, to expand on what Kent said, the leading coil wire goes in the L (center of cap), and the trailing goes into the T.
Old 05-21-06, 09:44 PM
FB Techie
Paradox_Racing's Avatar
It almost sounds to me like bad plugs or wires though. Could also be a bad distributor cap or rotor. I have had bad luck with the Neihoff caps and rotors that most of the auto parts stores sell. I usually order mine from Victoria British, as they sell the Bosch parts that seem to fit a lot better. Look inside your cap for signs of cracks or arcing.
Old 05-22-06, 07:42 AM
wheres my calculus book?
gmanuser's Avatar
you dont want to run tdc search the forums and thier is many advice on how to set the timming, it should be like -15 off tdc i belive but check the forums and they will tell you exactly.
Old 05-22-06, 08:08 AM
Have RX-7, will restore
mazdaverx713b's Avatar
Received 1,050 Likes on 890 Posts
its not the cap or rotor if you are getting spark at all. check your wires for continuity and check your ignitors connections and your coils.
windom
09-11-15 04:48 AM
SakeBomb Garage
Vendor Classifieds
09-07-15 03:44 PM
SakeBomb Garage
SakeBomb Garage
09-07-15 03:32 PM
Quick Reply: firing order
