How to find Mazda Part Numbers
Old 01-21-07, 08:26 AM
dgeesaman's Avatar
A lot of people ask for Mazda part numbers, when in reality they can find them even faster.
First, download the parts list for your model year. 96+ guys, good luck so far nobody has made those parts lists available.
In this example, I will find the part numbers for the relays mounted to the ABS unit.
Now open the PDF, skip past the first page, and look thru the pictorial index to find the section where the part will be. If you're looking for several different parts, it can help to jot down the section numbers. Be patient - this step is hardest since it's not always obvious which section has the part, and there are many sections. It will become less of a problem as you get to know how Mazda organized the parts.
Pictorial Index:
OK, the first page of the index is just engine and drivetrain parts. If you keep going, you'll find the section with the braking system.
Here it is: the ABS unit is in section 4370.
So scroll thru the whole PDF, looking at the section numbers on the top of each page until you find the right one. Some downloaded versions are divided into 3 files, so you may need to open a different file to get to the right section.
The scan quality of these parts lists isn't great, so it really helps to set the zoom of the document to 100%, 150%, or 200%. Anything in between just makes it harder to read.
Dig around and look thru the picture for the parts. Sometimes the illustrations are a little rough or crude. Also note that for some sections, the illustrations are spread over more than one page.
Here we see a couple of boxy shaped things that resemble the relays. Their position codes are 43-7A3 and 43-7A2. This is not the Mazda part number, but you're almost there.
Now look up those numbers in the right hand column. We see for part position 43-7A2 that it's a "Relay, Motor Hydraulic Unit". The Mazda part number is NA23-43-7A2, and there is a quantity of (1) per car. The second relay is listed right below it.
If the part is a fastener, it will have the Mazda part number listed beside it in the picture. For example: 99940-0801. These numbers can be the hardest to read, so it sometimes helps to check the same illustration on another page.
Pay attention to any notes about manual vs. automatic transmission, and option packages. "Hard susp." = R1 or R2 package.
Sometimes there are different versions based on the VIN number of the car, in which case you should know the VIN and look to the bottom of the parts page to see which one it should take. If it's an interior part you will need to choose a color suffix "-00" or "-02". These get added to the Mazda part number, for example "FD18-88-111-02".
If you want a price, take those numbers to a site like www.mazdapartscheap.com and enter it into their parts number search. You'll then get prices, and if the part has been updated since the parts list was scanned, an updated number too. If you choose to order from another source, use the updated (supercede) part number, although the dealer can use either one.
Dave
Attached Thumbnails How to find Mazda Part Numbers-pictorial-index-1.png   How to find Mazda Part Numbers-pictorial-index-2.png   How to find Mazda Part Numbers-abs-1.png   How to find Mazda Part Numbers-abs-2.png   How to find Mazda Part Numbers-abs-3.png
Old 01-21-07, 09:11 AM
All Spooled Up
badddrx7's Avatar
Good eye Dave.....This is all I've ever used since I downloaded the schematics onto Disc several years ago. Very easy to find parts.
Then I call Ray....
Old 01-21-07, 09:59 AM
Eye In The Sky
cewrx7r1's Avatar
We original car owners from the 90s have been doing this for years.
Old 01-21-07, 10:06 AM
RX-7 Bad Ass
DaleClark's Avatar
Received 2,437 Likes on 1,508 Posts
There's a PDF of the parts guide out there that's fully bookmarked in Adobe Acrobat. You click the Bookmarks tab, and it lists all the sections, makes it VERY easy to find the section you need.
I'm trying to find where I originally got the PDF's so I can post a link.
Dale
Old 01-21-07, 10:55 AM
RX-7 Bad Ass
DaleClark's Avatar
Just put them up on ClubRX -
http://www.clubrx.org/media/1993parts.pdf
http://www.clubrx.org/media/1994parts.pdf
http://www.clubrx.org/media/1995parts.pdf
These were compiled by Littlecat on the forum, but her site is down where it was originally hosted. Pull up the PDF, hit the Bookmarks tab on the left side, and you'll see all the sections, nice and easy to go through.
Dale
Old 01-21-07, 12:23 PM
No Paypal Accepted!
Buzzardsluck's Avatar
Nice, thanks guys.
Old 01-21-07, 12:27 PM
dgeesaman's Avatar
Mazdacomp has put these up for years and none of the racers ever needed directions. Hmm, coincidence?
Dave
Old 06-09-09, 03:32 PM
ricepower89's Avatar
cant we download them?
Old 06-09-09, 03:43 PM
dgeesaman's Avatar
The latest links to downloadable copies are kept here:
https://www.rx7club.com/forum/showthread.php?t=614824
Old 01-15-12, 10:53 PM
danny hahn's Avatar
did this thread make the FAQ for 3rd Gen & other useful links list?
Old 01-16-12, 05:16 AM
FD Project
BLACK MAMBA's Avatar
Thanks guys, just downloaded my.
Old 01-16-12, 12:55 PM
needs more track time
gracer7-rx7's Avatar
Good info Dave.
But who needs parts numbers when we have Ray Crowe?
Old 01-16-12, 01:51 PM
dgeesaman's Avatar
Originally Posted by gracer7-rx7
Good info Dave.
Ray's allowed to have quiet nights and weekends. But it is fun to look up the part numbers and quiz him anyway. He has a lot of them memorized.
Dave
josef 91 vert
23
09-03-15 11:20 AM
04G35S
08-14-15 07:31 AM
Quick Reply: How to find Mazda Part Numbers
