Coolant Overflow Tank Vent Hole
Old 06-03-07, 03:41 AM
The Black Seven's Avatar
Where exactly is the vent hole for the Coolant Overflow tank? When I was filling coolant in the overflow tank, the coolant was pouring out from the rubber piece between the neck and the tank. By the way the rubber piece looks really brittle. Do I need to replace the overflow tank? or is this where the vent hole is at?
Old 06-03-07, 04:00 AM
putting it back together
blwnrtr93's Avatar
There is only one easy way to get to the overflow tank, and it's not really all that easy. I found that the easiest way to get to it is to remove the front bumper. Mine was already off since I'm replacing it with an aftermarket piece.
Old 06-03-07, 01:15 PM
Blithering Idiot
dontlift's Avatar
Why the hell are you filling that tank??? Only add to it when it's below the low mark. It's called an expansion tank for a good reason -- you need to leave room in it for the coolant expanding when your engine's hot.
You shouldn't let it get above the F mark (when the engine is cold).
Old 06-03-07, 01:21 PM
~17 MPG
scotty305's Avatar
Fill coolant at the filler neck. See section 5: Maintenance...
The Big Fat FD3S Cooling Thread:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/big-fat-fd3s-cooling-thread-571088/
-s-
Old 06-03-07, 02:10 PM
Got it, fill from filler neck and AST. But I am still curious where the vent hole is located at.
I was looking down the end of the neck area where it meets the base (a black rubber piece that looks hard and cracked) and saw the coolant leaking out from there. I'm kinda freaked out from there. But I hope that's the spot.
Old 06-03-07, 02:15 PM
Blithering Idiot
dontlift's Avatar
I don't there is a vent hole per se -- it's not supposed to get that full. The neck simply acts like a funnel into the reservoir, so it'll leak from the top if you overfill it (or it boils over).
Old 06-03-07, 02:16 PM
Recovering Miataholic
wstrohm's Avatar
You can get to the expansion tank by removing the right side fender liner. Not that hard... you can also remove that tank once you have done that.
Old 06-03-07, 02:22 PM
Derek
DMoneyRX-7's Avatar
someone just post a pic of the damn thing
Old 06-03-07, 09:05 PM
What's your point ?
CantGoStraight's Avatar
There is a vent hole on top of the recovery tank (I know because I put an elbow with a tube in it so the coolant would come out in a specific spot if it overflowed instead of it going all over the belly pan and frame work to wher eyou only had a general idea of where it originated from.
Old 06-04-07, 08:27 PM
Derek
DMoneyRX-7's Avatar
Is their supposed to be a black spongy thing with tape at the very bottom of the neck when it connects to the tank?
Old 06-04-07, 08:31 PM
7-itis
edwin-82/rx7's Avatar
Yes, my brand new one I just bought from Ray has that.
The hole at the top of the overflow tank is a vent to equalize pressure, so that coolant has a spot to flow easily when it is vented from the ast, and so that coolant recovery can happen easily without fighting a vacuum in the overflow tank.
J
Old 06-04-07, 09:30 PM
Blithering Idiot
dontlift's Avatar
Originally Posted by CantGoStraight
There is a vent hole on top of the recovery tank (I know because I put an elbow with a tube in it so the coolant would come out in a specific spot if it overflowed instead of it going all over the belly pan and frame work to where you only had a general idea of where it originated from.
You're right -- I never noticed it. Good idea with the tube, btw.
Interesting, mine (an early '93) has just the white plastic fill tube going into the tank. For the OP, the arrow points to the vent hole:
Attached Thumbnails Coolant Overflow Tank Vent Hole-coolant_tank1.jpg   Coolant Overflow Tank Vent Hole-coolant_tank2.jpg
09-16-18 07:16 PM
mulcryant
09-09-15 05:24 PM
ZaqAtaq
09-05-15 08:57 PM
Quick Reply: Coolant Overflow Tank Vent Hole
