TPS unplugged...Car runs BETTER..why?
Old 06-23-07, 12:25 PM
Turbo Waggin
endneu913's Avatar
As stated above.... after a round of mods... TB mod, rets nest removal, BAC ACV and EGR block offs... the car was a bear to start, now it hesitates so badly it feels like 1/4 power 99% of the time. I unplugged the TPS for adjusting and the car smoothed out and ran almost perfect, save a burp and a hiccup at 2800 and 4000........ several other people have found this problem, when i searched, but no fix was ever suggested? anyone else have this problem?
Old 06-23-07, 12:31 PM
'89 GTUs
Omixeo's Avatar
I have this problem as well. My narrow range tps is broken, so i leave it unplugged until I can find another one to replace it.
Old 06-23-07, 12:49 PM
Funkspectrum's Avatar
bad tps....replace it.
Old 06-23-07, 01:04 PM
jackie chan > chuck norri
celbii's Avatar
Old 06-23-07, 03:07 PM
Turbo Waggin
endneu913's Avatar
By narrow range, you mean the one that bolts to the front of the UIM? the black box with the black cylinder that presses in.... if yes, i did replace it with a used one that was known to work. It didnt solve the problem.....
Old 06-23-07, 07:30 PM
And the Revolution...
DarkKnightFC's Avatar
after you remove that stuff you will have to set the throttle stop screw to control idle, and therefor adjust the tps so it is reading correctly also. FC3SPRO.COM has a write up.
Old 06-24-07, 12:29 AM
Turbo Waggin
endneu913's Avatar
Throttle stop screw as in the idle screw on top of the UIM?
Old 06-24-07, 06:28 AM
HAILERS
HAILERS's Avatar
As in put the BAC back on the engine and set the idle per the FSM.
Old 06-24-07, 11:18 AM
Turbo Waggin
endneu913's Avatar
okey dokey smokey
Old 06-24-07, 11:35 AM
always searchin
lnlycrpr's Avatar
after the TB mod and rats nest removal. i had to adjust my TPS and idle. you'll have to find a happy medium, b/c you wont have the idle and TPS reading that you used to.
my care idles around ~900rpm with it reading .920k now. i guess that's the best itl'll do.
how was your TPS before the TBmod??
Old 06-24-07, 06:24 PM
M.C. Language's Avatar
dont take this the wrong way, "if i unplug the tps the car runs better" do you think you might have a bad tps?! seeing how a bad tps is a very common problem... change your tps holy ****
Old 06-24-07, 08:41 PM
LeeTheSlacker's Avatar
my turbo car runs better with it unplugged.
my na did the same thing, any load and it would stall. unplugged tps, went away. came back a day later, plugged it back in, ran fine. then acted up again, so i just adjusted it till the idle stopped bouncing and now its good.
Old 06-25-07, 02:12 AM
Turbo Waggin
endneu913's Avatar
IT was fine... worked perfectly, using a DMM anyway, i set it to 100 and found no dead spots....
Old 06-25-07, 02:15 AM
Turbo Waggin
endneu913's Avatar
yeah you'd think so huh, but like i said, i tried a different TPS i got from a friend... who said it worked fine...(yes thats an ASSUMPTION) . and the car suffered the same symptoms when plugged in... besides, although weird **** does happen, have you ever heard of a TPS deciding it wanted to die in a matter of hours.... specifically the hours it took me to do the work? too weird
Old 06-25-07, 02:18 AM
Turbo Waggin
endneu913's Avatar
so you had the hesitations, so you unplugged it... then they came back.. unplugged? and you plugged it back in..?.... and then you adjusted the idle ect... with it plugged in or unplugged? im curious
Old 06-25-07, 01:37 PM
strange... sorry for the attitude, i was un aware of the attempt of a different tps.. thats wierd.. i would say try another.. his is probably silly to. you would be amazed how many fc's there are around with bad tps sensors and the owners have no idea
Old 06-26-07, 10:45 AM
Turbo Waggin
endneu913's Avatar
Hey no sweat..... yeah, i was thinking about getting a brand new one.... but thats lotsa bucks! does anyone know of a better way of ensuring their operabilty? other than using a DMM......
07-01-23 04:40 PM
82streetracer
Haltech Forum
11
03-11-19 05:34 PM
befarrer
Microtech
08-22-15 05:52 PM
eddierotary
08-16-15 04:12 PM
ncds_fc
08-15-15 10:06 AM
Quick Reply: TPS unplugged...Car runs BETTER..why?
