Rtek Forum Discuss the Rtek 2.0 and other Rtek ECU's
Rtek rtec & safc II
Old 09-25-07, 08:17 AM
my-sons rx7's Avatar
rtec & safc II
I have the rtec 1.7 can I run the safc II with that or do I need to get a different ecu Thanks Tony
Old 09-25-07, 08:44 AM
RotaMan99's Avatar
Rtek is a fuel and timing EM chip that can do way more then the SAFC can.
If you have a Rtek, you do not need a SAFC or another piggy back or a standalone. You do not want to run two engine managment controlers together at all.
Old 09-25-07, 10:47 AM
gross polluter's Avatar
You missed that he had a 1.7, not a 2.0. The 1.7 is not programable like the 2.0.
With that said, I run an SAFC with my 1.7 to dial things in a bit more. There's too many different types of injectors out there for the 1.7 to work perfect on every setup without some fine tuning. I would highly recomend a wideband to use in conjunction with the safc.
Old 09-25-07, 11:03 AM
turbo2ltr's Avatar
Old 09-26-07, 07:00 AM
RotaMan99's Avatar
Ah yes I did. I automatically though about the 2.0. Sorry OP
Old 11-23-07, 07:32 PM
Stock206's Avatar
gross poluter:
Which injector pesets do you have for your RTek 1.7? And are you running a SAFC or an SAFCII?
Old 11-23-07, 08:35 PM
turbo2ltr's Avatar
The 1.7 doesn't have presets that you can change. It's for 550/720
Old 11-23-07, 08:38 PM
The 1.x series ECU's are not programmable, so there's no "presets" beyond what the ECU is programed for. The 1.7 is set for stock primary and 720cc secondary injectors. I ran an SAFC and used a ZT-2 and Pocketlogger ZT for AFR monitoring, for balling on a budget it's a very solid setup.
The SAFC and SAFC-II modify the airflow signal in the exact same manner so functionality wise there's not much difference with exception of more tuning points on the SAFC-II.
Ninja edit: Mike beat me to it.
Old 11-20-08, 03:31 PM
Hookt UP
J.MurdaFCs3's Avatar
"ninja edit"
Hilarious!!!
Im bout to get a SAFC too, for a lil fine tuning
SaabGuy
19
02-04-04 08:25 PM
rx7_88turbo2
05-25-02 07:18 PM
SaabGuy
04-21-02 07:16 AM
crossbar17
11
04-01-02 09:20 AM
Quick Reply: Rtek rtec & safc II
