Car Won't Crank/Start. Just makes One Loud Click (Starter?)
Old 05-12-09, 02:38 PM
rosrex7's Avatar
Day 2 .. the Saga continues...
Just tried putting a socket on the crank shaft after loosening all the belts and it wont budge or rotate in either direction put it in gear and rocked it as hard as i could and couldnt get anything out of it that way either..
perhaps teh engine that i just bought 4 months ago has seized?
Old 05-13-09, 06:34 AM
rosrex7's Avatar
Bought and Replaced Battery this morning. attempted to start and there were no changes in the problem
however, on about the 5th crank a puff of smoke came up from the fire wall.. upon inspection, The ground wire that connects the UIM and the fire was has melted..This wire is not connected to anything all the fuses appear to be good.
I am at a loss.. Dont know where to start trouble shooting now.
going to try and push start it to see if that gets the engine to turn over.
Attached Thumbnails Car Won't Crank/Start. Just makes One Loud Click (Starter?)-_media_card_blackberry_pictures_img00222.jpg   Car Won't Crank/Start. Just makes One Loud Click (Starter?)-img00221.jpg
Old 05-13-09, 09:29 AM
Racecar - Formula 2000
DaveW's Avatar
This says that you have a MAJOR grounding problem from the engine ***'y to the battery. The wire that melted should never have to carry enough current to even get warm.
As a quick diagnostic, hook a jumper cable from the engine ***'y to the ground side of the battery. If the engine cranks, you definitely have a ground issue.
07-01-23 04:40 PM
bb6guy
Old School and Other Rotary
10-01-18 08:07 AM
befarrer
08-14-15 04:18 PM
bb6guy
08-12-15 03:29 PM
Quick Reply: Car Won't Crank/Start. Just makes One Loud Click (Starter?)
