Still losing coolant, no idea where??!!!
Old 03-25-08, 05:08 PM
the one and only
axnjaksn's Avatar
Allright i'm still losing coolant and I haven't the slightest idea where, holds 20 psi at the cap, runs fine, no white smoke at all, no visual leaks under the hood or car, holds fluid with the plugs out, is it an airbubble somewhere taking forever to find or what???????????
Old 03-25-08, 05:11 PM
fadedvr=pink
pinkrx7's Avatar
you sure your ast isn't leaking at the cap?
Old 03-25-08, 05:40 PM
sleeper
4CN A1R's Avatar
whats determining your losing coolant?
Old 03-25-08, 07:35 PM
fadedvr=pink
pinkrx7's Avatar
prolly the fact that e takes of the coolant cap and its not at the top
Old 03-25-08, 09:58 PM
I luv my carbon footprint
mgoddard1's Avatar
When you check the level in the overflow tank when the engine is cold is it consistent or is it dropping as well? If you take the filler cap off when the engine is cold the coolant level will drop due to the suction caused by the cooling system pulling coolant back in from the overflow tank when the engine cools down.
Old 03-25-08, 10:33 PM
needs more track time
gracer7-rx7's Avatar
Remember that water/coolant expands and contracts when heated or cooled.
Old 03-26-08, 12:36 AM
the one and only
axnjaksn's Avatar
Ima keep an eye on it tomorrow, but I may just be freaking out and not loosing any coolant, cars has been getting warm and I just re-wired my stock fans to get maximum voltage and I think that may solve my hot issue and stop me from popping the cap all the time!!!
Old 03-26-08, 05:35 AM
sleeper
4CN A1R's Avatar
have you flushed the coolant system lately?
Old 03-26-08, 08:32 AM
mrb63083's Avatar
Also... do you have the factory AST?
rgordon1979
40
03-15-22 12:04 PM
HalifaxFD
Canadian Forum
126
05-09-16 07:06 PM
JoesFC
10-05-15 08:10 AM
Monsterbox
09-11-15 03:29 PM
ZaqAtaq
09-05-15 08:57 PM
Quick Reply: Still losing coolant, no idea where??!!!
