Naturally Aspirated Performance Forum Discussion of naturally-aspirated rotary performance. No Power Adders, only pure rotary power! From the "12A" to the "RENESIS" and beyond.
How much horse power is possible out all motor?
Old 06-15-08, 08:09 PM
njs619's Avatar
Hi I was wondering how much horse power can I get out of by staying all motor? I'm looking to get 400 to the wheels. Would this be hard to obtain? Also I used the search button but, can't find my answer. Thanks..
Old 06-15-08, 09:05 PM
hondas suck hard
ibrakestuff's Avatar
400 isnt gonna happen dude. 300 mabee but will cost you alot of money and wont be streetable. 200 is more of a obtainable goal for a streetabe 13b
Old 06-15-08, 09:36 PM
njs619's Avatar
Thanks for the reply.. So 400 i would need to go with a turbo setup?
Old 06-15-08, 10:18 PM
mazda mario
mario1386's Avatar
FL
yes,with a turbo; every horsepower range is possible.
Old 06-16-08, 12:30 PM
Rotors still spinning
rotarygod's Avatar
The only way you'll get 400 all motor with a rotary is to use a 3 rotor and even then you aren't going to get it without a bridge or peripheral port. It'll also cost more than just going turbo and will have many negative driving side effects.
Old 06-16-08, 12:35 PM
Respecognize!
Whizbang's Avatar
200 hp + 4.778 gears and a 2200lb car isn't bad!
Old 06-16-08, 04:33 PM
yomo's Avatar
4.778 Final Drive FTW!!!
wait, where can I get one of those
Old 06-16-08, 04:55 PM
njs619's Avatar
So to get the most horse power out of the rotary is to port and polish,Intake,Exhaust? Thanks
Old 06-16-08, 05:54 PM
nvrdone's Avatar
I want that diff!!!
Old 06-16-08, 06:13 PM
Home-brew Rotary
NoviceRotaryTech.'s Avatar
Try searching...
Beefy N/A threads.
N/A build-up threads.
N/A porting.
N/A tuning.
etc.
etc.
Theres alot you can do / have to do to make a "powerfull" all motor rotary car.
Old 06-16-08, 08:17 PM
yomo's Avatar
rotoring porting is a lil different than on regular engines... it similar to putting bigger cams in
Old 06-16-08, 08:29 PM
rotarygod's Avatar
4.77 FTL. 4.10 is plenty. Sorry.
Old 06-16-08, 11:44 PM
dj55b's Avatar
Do not polish the intake, just the exhaust.
Old 06-17-08, 08:38 PM
njs619's Avatar
Thanks guys.. All of u guys are running all motor, what kinda of power are you guys making?
Old 06-17-08, 11:32 PM
dj55b's Avatar
I think that most average people with a decent tune are seeing around the 170ish HP mark, if you go a little more crazy with the porting and better intake and exhaust tuning, 200ish hp, then go P-Ports, and insane Bridge ports and J ports, and you can see the 200-250ish HP, but take alot of time and money to develop something like that which is why if you're aiming even for around the 200 HP and above area alot of people just opt out for a turbo charger as its easier and cheaper.
Personally I have a 12a Street Port, with ITB's and a pretty decent exhaust setup, and I'm aiming around the 170whp area with it. I think I'm closer to 165 right now but with a cooler air setup, better heat shielding and cooling, I should be getting closer to my target HP. With a Lightweight car, 200hp is still a plentiful for the street.
Old 06-19-08, 02:12 PM
The Silent but Deadly Mod
Roen's Avatar
5th gear is completely useless then!
5.12 for me, if not a custom 5.77 setup.
Old 06-19-08, 08:50 PM
rotarygod's Avatar
Why the hell would you want to shift every 7 mph and top out at 26? Exaggerration but you get the point. Everyone wants more. Here's a big secret in the performance world. More is almost NEVER better! More gearing is not neccessarily better. Bigger ports and more port timing is not neccessarily better. Higher rev limits are not neccessarily better. There is a place for everything though. It's called the race track. If you only use the car for autocross and that's what your shift points dictate is optimal, then I can understand. If this is a street car and you somehow feel that aggressive gearing is what is neccessary to beat a Honda Civic off the line, then I think you're nuts! There's a place for everything. The street isn't where being super aggressive makes you fast though.
5th gear is for cruising. That's what it's intended to do. It's supposed to keep the engine at lower rpms. It's not a performance gear. That's what you've got 4 others for. The gear ratio splits on the stock transmission are not optimal for high performance anyways. You'd have to completely regear it all and get them all closer together. Just changing the rear end ratio to somehow bandaid the stock gear ratios into being a bit quicker is a ghetto rigged way of going about performance and it will always fall short. Too many people don't understand gearing. They feel any one piece is the answer. You'd be better off going with a Guru Dogbox for performance. It's meant for the track which means 5th gear isn't an overdrive. Overdrive and high performance don't belong in the same sentence. An aggressive rear end won't make that true either.
Old 06-19-08, 09:20 PM
Roen's Avatar
Have to keep stock tranny in my class, but R&P is unrestricted. 5.77 will top out 5th gear right at redline at ITS power levels, according to my calcs.
Old 06-19-08, 10:55 PM
ultimatejay's Avatar
Oh really? Then get out your horsepower calculator and tell me how much horsepower you think this all motor rx7 is making.
http://www.youtube.com/watch?v=FWlaFqqUSNU
Old 06-20-08, 03:18 AM
yomo's Avatar
damn
my friends 850whp integra only ran a 10.01. thats crazy that an allmotor goes that fast.. no turbo lag FTMFW!!!!!!
Old 06-20-08, 10:24 AM
Roen's Avatar
How much does the car weigh?
100 hp would accelerate 100 lbs pretty damn quickly.
Old 06-20-08, 03:57 PM
That car has full glass and interior, roll cage minus stock front seats and has race
seats. So whatever a first gen weighs- 2300lbls +or- a few. That engine is putting over 400 to the ground I can guarantee that and I know a few other who are doing the same.
Old 06-21-08, 02:09 AM
'Tuna'
crispeed's Avatar
I know but I'm not telling!!!
I also know how much power it takes to run those times and mph in a 2100lb vechicle.
Old 06-21-08, 09:57 AM
So do I.
Old 06-21-08, 10:17 AM
'Tuna'
crispeed's Avatar
So do I.
Quick Reply: How much horse power is possible out all motor?
