92 - 2002 Efini Rx7 FD3S Help
New to Improve
on
I've searched with every possible search i could think of and have got no results yet!
I hope there is someone out there somewhere i can obtain a electronic copy of wiring
diagrams for my 92 JDM Efini Rx7. My cooling fans do come on with my AC. I've tried using the wiring diagrams from the 93's that were sold in Northern America but found the wiring dose not match the car! I'm not at a loss. i've checked my Relays, Fuses, tried the test procedures and they failed as well. Any help would be greatly appreciated.
New to Improve
on
My Cooling fans do not run at all. I turn on the AC nothing happens! I know the Thermo switch is dead cause the fans don't come on when they are suppose to at 105C i believe that's the temp they kick on at. They work if i feed power directly from the battery.
New to Improve
on
Ok guys! I've replaced the water Temp. switch with a new switch for a turbo FC to get the fans to come on at 95 deg. C, Turning on the AC will turn on the fans now but they still don't click on at 95 deg. C. I've checked the relays for continuity, they have it, all fuses are good. Any ideas ???
