widest tire size on a 8 rim
Old 09-02-08, 01:10 PM
1BAD20B
bewtew's Avatar
what is the widest possible tire to fit in a size 8 rim and 8.5
i got 245 on 8 rims and i would like to go a bit wider
Old 09-02-08, 01:35 PM
Mr. Links
Mahjik's Avatar
It will depend on the tire. Most tire manufacturers recommend 8" as the smallest rim for a 245 tire and 8.5" as the smallest rim for a 255 size tire.
Old 09-02-08, 04:38 PM
Josh18_2k's Avatar
depends on sidewall too. mustang people put 275's on their stock 17x8's.. not good for cornering, but adds some meat if you're just trying to go strait.
Old 09-02-08, 09:40 PM
Newbie
scradley's Avatar
ive mounted 275's on 8's before. "recommended size" means they are just covering their ***
Old 09-02-08, 10:14 PM
Mr. Links
Mahjik's Avatar
Just because you can, doesn't mean you should. I can drive a car with my feet; however, that doesn't mean I should.
Old 09-04-08, 12:08 PM
1BAD20B
bewtew's Avatar
i get it.. i just want to get a little bit more traction but at the same time i dont want to loose the handily
Old 09-04-08, 06:15 PM
Josh18_2k's Avatar
width has a much smaller effect than compound. i'd go with 255's, and get some sticky tires.
falken RT-615's are prolly your best bet. (they come in 255/40/17)
Old 09-04-08, 08:58 PM
RIP Mark
YaNi's Avatar
I just bought some mustang 17 x 8 wheels with 275mm tires on them. The sidewalls are no where near a vertical. The largest tire you should put on an 8" wheel is a 245; I'm going to run 225mm RT-615's on them.
Old 09-15-08, 12:51 AM
tinkerguy's Avatar
I have bridgestone 255 po3's on 18x8.5's. They look to be a great fit. I don't think I'd go any wider. Same with the 285's on my 18 x9.5's
SakeBomb Garage
Vendor Classifieds
08-09-18 05:54 PM
Quick Reply: widest tire size on a 8 rim
