FC turbo manifold to T3 adapter
Old 12-15-08, 10:49 AM
rotorhead
arghx's Avatar
I wonder if these guys could make one?? http://stores.ebay.com/MC-Motorsport...QQftidZ2QQtZkm
they say they do custom adapter flanges. You would have to send them the gasket (of course s4 and s5 are different), and then you could run a larger internally wastegated turbo like a GT30 or a Holset HX35--assuming that their wastegates could actually control boost, which is questionable. It would be cool to try and adapt an s5 turbo manifold (which is fully divided) to a Holset HX35 off a Dodge Ram, which is divided T3 and internally wastegated.
Old 12-15-08, 11:08 AM
The waiting game......
2slow4stock's Avatar
Try it out and let us know :P But external wastegate is better IMO.
Old 12-15-08, 02:55 PM
rotorhead
arghx's Avatar
I wish I had the money and an extra car. I wonder if you could take an s4 manifold and make a T3 adapter, and then for an external wastegate use something like this (if there's enough clearance at least):
http://cgi.ebay.com/ebaymotors/T3-TU...Q5fAccessories
then you could bolt up an undivided T3 GT35R or an OEM turbo like a Borg Warner s200 or Holset HY35.
Old 12-18-08, 02:38 PM
That would work. I'm sure someone makes it. But yes, clearance is an issue with that. Why not just buy a t3/t4 manifold? Some t3/t4 turbos come internal waste gate. So maybe..
Old 12-18-08, 09:21 PM
4th string e-armchair QB
Trots*88TII-AE*'s Avatar
I think it would be more worthwhile to go either BNR, or to save up a little more and get a proper manifold/turbo.
Old 04-27-09, 04:09 PM
mo-powah's Avatar
whats a bnr? and where do u get a proper manifold?!
Old 04-27-09, 05:49 PM
tigerbite's Avatar
Go to BNRturbos.com
Old 04-27-09, 08:07 PM
mo-powah's Avatar
i didnt see any manifolds just really expensive stock turbos
Old 04-27-09, 08:30 PM
The Firestarter
WingsofWar's Avatar
BNR turbos are BOLTON replacements for stock turbos, they are reworked and allow you to use your stock turbo manifold.
VS
when you buy a new manifold, you will not be able to use the stock turbo, which means you must find and build all the components yourself to upgrade your turbo. Or you can buy a turbo kit package from major tuning companies for 2-5 grand
Turblown
Vendor Classifieds
08-18-15 10:01 PM
Quick Reply: FC turbo manifold to T3 adapter
