Super Lightweight Rotor Asssembly
Old 03-24-09, 07:05 PM
cmsgama's Avatar
Hi
I have a rx7 s5 13bt, how much RWHP is possible gain with a Super Lightweight Rotor Asssembly, in this case, the racingbeat Super Lightweight Rotor Asssembly, wich each rotor weights less 1LB? What the benefits?
regards
Old 03-24-09, 07:39 PM
Pop Pop BANG FIRE!
jake1191's Avatar
from what ive read nothing unless its a race motor
Old 03-24-09, 07:46 PM
Turbo power, activate!
Black Knight RX7 FC3S's Avatar
you wont gain any significant hp
but you can rev higher more safely and the engine will be way more responsive
Old 03-24-09, 07:47 PM
bosozo9's Avatar
yeah... pretty much like getting a lightweight flywheel
Old 03-24-09, 07:48 PM
Retired Moderator, RIP
misterstyx69's Avatar
Originally Posted by cmsgama
Hi
DUDE,you really have to RE-read the INFO.
they take One pound OFF,so the Rotor is now 8.7 pounds,not 9.7 pounds(stock).
when I read your post,I thought Holy Crap!..they are Making the Rotors Out of Tin Foil!
Old 03-24-09, 07:55 PM
cmsgama's Avatar
Sorry the confusion.
but if each rotor wheights 8.7pound, are 1pound less than stock. 2 pound less in the assembly, I think that the engine have any benefit, or not?
Old 03-24-09, 08:11 PM
bosozo9's Avatar
not on a stock motor
Old 03-24-09, 08:55 PM
Boost knob
incubuseva's Avatar
You might get better gas milage too.
:giggle:
Old 03-24-09, 09:24 PM
NASA-MW ST4
farberio's Avatar
Yes it will have a benefit, and if you can afford to put them in your car more power too you. However this mod is obviously very expensive and there are many other things you can do to your car that have the same or better benefits for a lot less money.
Old 03-25-09, 04:12 AM
cmsgama's Avatar
I know that the cost of this, I can bay a turbo kit a gett much more power. But I want know, if existe benefits, what benefit? I get 10RWHP or more? rev faster? more responsive?
Old 03-25-09, 04:37 AM
They live We sleep
rx7_FREAKKK's Avatar
You would be better off Just Inflating your tires to 50lbs and greasing up your wheel bearings and Wax the car.
Old 03-25-09, 10:15 AM
Engine, Not Motor
Aaron Cake's Avatar
The engine will rev higher and be more reliable at those speeds. An increase in throttle response is also a result. However you will make less low end torque due to less rotating mass.
This is really a race modification only for aggressive ports like full bridge or peripheral. This is mainly an NA mod, since turbo engines don't have to rev up to make power (just turn up the boost).
sinclair7seven
11
09-11-15 10:15 AM
Quick Reply: Super Lightweight Rotor Asssembly
