Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
Best Wideband O2 sensor?
Old 04-08-09, 06:56 PM
M14socom's Avatar
I am currently looking for a wideband o2 sensor. I need to know what would be my best choice for value, I don't want to spend a grand on one. Any information would be appreciated.
Old 04-08-09, 07:11 PM
Bubblicious DEF.
muibubbles's Avatar
im used the AEM WB with my 8 and getting one for my 7... believe they come with bosch..
Old 04-08-09, 07:47 PM
M14socom's Avatar
Are you talking about the aem 6-1 eugo controller?
Old 04-08-09, 08:06 PM
Bubblicious DEF.
muibubbles's Avatar
yep, 6-1 is just the face/bezel combinations if i remember correctly
Old 04-08-09, 08:39 PM
M14socom's Avatar
Anyone else have anything to say about the aem one? Is there a better one?
Old 04-08-09, 08:51 PM
rothvanberg's Avatar
I like the inovate lc-1 with db gauge kit better than the aem kit
Old 04-08-09, 09:05 PM
rotorhead
arghx's Avatar
depends what you want to do with it. if you want to run race gas and keep accuracy you need something with an NTK sensor (like the NGK AFX)
Old 04-08-09, 09:09 PM
Defined Autoworks
FDWarrior's Avatar
innovate makes a good wideband.
Old 04-08-09, 09:33 PM
ChumpCar**Apex of Failure
parid's Avatar
+1 for the innovate lc-1/lm-1
Old 04-08-09, 10:29 PM
Bubblicious DEF.
muibubbles's Avatar
yeah aem is like a moderate level? innovative is like baller status.. since all they really make are wb..... pricey tho
Old 04-08-09, 10:50 PM
Finally Knows
WaachBack's Avatar
Innovate LC-1
Old 04-08-09, 10:59 PM
blacksi's Avatar
I returned the POS innovate to run an FJO and haven't had anymore issues. With the LC=1 you have to do free air calibrations and crap and after sitting over the winter last year I couldn't get it to work again. I have had 0 problems with my FJO.
Old 04-09-09, 08:38 AM
rotorhead
arghx's Avatar
the early model LC-1's were problematic (6 wire models). They should be avoided. The calibrations are not a big deal at all. They are there to improve the accuracy of the factory sensor calibration. Calibrations are used in OEM wideband applications (VW). You press a button (or flip a switch) for a few seconds and then you don't have to worry about it again for a long time. The wiring seems confusing at first but there are writeups on here.
If you plan to do any datalogging on a datalogit, stay away from the AEM, as it is problematic in that department.
Old 04-09-09, 08:28 PM
M14socom's Avatar
Yea I'm definitely going to be using it datalagit. Does that mean the lc-1 would be the best choice?
Thanks to everyone for the information.
Old 04-09-09, 09:17 PM
M14socom's Avatar
The LM-2 seems like a pretty good deal, does it work in conjuction with datalogic? It would be nice because I could use it on my other cars "eagle tsi and camaro", would it be worth the extra 100 or so?
Old 04-10-09, 09:47 AM
M14socom's Avatar
So If I'm using a Power Fc should I go with the lm-2 or lc-1?
Old 07-21-14, 12:50 PM
RX.....7 days a week
Turtle13's Avatar
Whats the difference between the LC-1 and LC-2?
Old 08-22-14, 09:18 PM
Vicoor's Avatar
I've been using the LC-1 for about 7 years. I like it because you can tweek the output so you can match the digital reading and the analog reading to your engine management.
Two things I don't like about it is the form factor, and It needs sensor replacements too frequently. (Man I shouldn't have said that because my sensor will die tomorrow)
But really it's been more than a year since I replaced the one I have now.
As far as the form factor, Innovate has a digital gauge with a integral controller now (like the AEM), so that would take care of the form factor part.
To the question what's the difference between a LC-1 & LC-2, The LC-2 is the new version and as far as I know it replaced the LC-1
I think I'd try the NGK Powerdex AFX if I was in the market now though.
Old 08-23-14, 03:49 AM
talking head
bumpstart's Avatar
ahem.. at the risk of thread necro
the PLX AFR and DM6 touch screen system is now gen 4 and features lsu 4.9
and new features including health status
i use the gen2 plx afr2 ( lsu 4.2 ) in my daily user and it has been faultless
and it displays trend, warning flags and displays in my choice of petrol/diesel/lpg/methanol AFR or in lambda
one of the cheaper units out there,, with no issues with burning up the probes , and unique display and features
rotor_veux
09-19-15 07:13 PM
Quick Reply: Best Wideband O2 sensor?
