How to Clean Engine Rotors, Housings, and Irons
Old 11-17-09, 11:09 AM
1.5 Goodfella's Tall
Gringo Grande's Avatar
I couldn't seem to find a thread that specifically dealt with this issue...probably my search-fu is weak. However, as I have just torn apart my first engine, I would like to hear what experienced builders have to offer in regards to cleaning various parts.
For instance...I know many people suggest the wire wheel route on rotors. I also know of someone who takes their parts to a machine shop and has them briefly left in a chemical dip of some sort to remove everything (my personal question about this would be is it dangerous for the nitride surface of the irons?). I also have had suggested to rent a steam cleaner as used on the underside of cars or even go to the local car wash and spray everything down as well as media blasting (exterior only!).
Any advice or tips would be appreciated.
Old 11-17-09, 02:28 PM
rotorhead
arghx's Avatar
www.rebuildingrotaryengines.com
get a pick set and be VERY thorough with coolant seal grooves
Old 11-17-09, 05:36 PM
Hi Arghx...I appreciate your input but nowhere in those videos does it talk about cleaning the plates or externally cleaning some of the pieces outside of the rotors. Certainly a great resource for anyone who didn't know about those videos!
I'm hoping some experienced builders will reference techniques they use to clean the oil, buildup, etc, etc. on parts to hear what else is common. Thank you again for sharing.
Old 11-17-09, 06:01 PM
Captain OCD
SoloII///M's Avatar
For the rotors, Pineapple racing has a great video. I used a brass wire brush on the faces with some kerosene to remove the carbon. Use an old side seal to thoroughly clean the side seal grooves of carbon. Use a wire wheel on a moto-tool to clean the corner seal grooves. Use an old apex seal to clean the apex seal grooves.
For the irons, clean the outsides with a wire brush and simple green or kerosene. I don't recommend simple green for the rotor housings because it can do a number on the aluminum. But the wire brush works great.
To prep the irons, follow Lynn Hanover's instructions. Use 180 grit aluminum oxide paper on a random orbital sander to remove the water staining and shine. Then slap on a 400-500 grit silicon carbide (wet / dry) disc or piece of paper, flood the housing with kerosene and sand it with the orbital until it has a matte grey finish. Use medium pressure and avoid the legs because you can chew through them.
Powerwash the housings at the carwash or at home if you have a powerwasher. Remove all the rust from the rotor housings with this method.
WD-40 on the iron faces until you're ready to build.
The following users liked this post:
Fickert (04-12-19)
Old 11-17-09, 06:14 PM
PvillKnight7's Avatar
I use broken side seals to remove deposits. I use a wire wheel to clean the rotor face but stay away from the apex grooves. I use a 5 gallon bucket with some degreaser, a tooth brush, and a brass brush to clean everywhere else on the rotor. Then I hose the rotor off with the garden hose and blast it all over with compressed air.
Don't touch the bearing unless you plan to replace it. Have fun.
Broken side seals also work well in the o-ring grooves on the plates.
Old 11-17-09, 07:19 PM
Any input on cleaning the exteriors of the housings or plates?
Old 11-17-09, 07:57 PM
Captain OCD
SoloII///M's Avatar
Look two posts up.
Old 11-17-09, 09:02 PM
Look two posts up.
He specifically referred to a rotor, nothing else.
Old 11-17-09, 11:51 PM
rotorhead
arghx's Avatar
a lot of people just put them in parts washers with carb cleaner
Old 11-18-09, 04:43 AM
Captain OCD
SoloII///M's Avatar
"For the irons, clean the outsides with a wire brush and simple green or kerosene. I don't recommend simple green for the rotor housings because it can do a number on the aluminum. But the wire brush works great."
Old 11-18-09, 10:51 AM
Engine, Not Motor
Aaron Cake's Avatar
It is hard to beat a parts washer. I use mine to clean everything but the eccentric, which I just hose with brake cleaner.
Make an initial wash in the parts cleaner to get rid of junk. Then go back and clean again, scraping all the grooves in the irons. Wash with soap and warm water, dry with compressed air. Clean the rotors by soaking in cleaner (watch out for the bearings!) and then rinsing. Scrape the grooves with old seals and carb cleaner.
After the first cleaning, scrape the irons again in the parts washer and use a Scotch Brite pad to clean up the surface. Wash with degreaser, soap and water, then dry thoroughly with the air compressor.
justino1125 (01-11-22)
Old 11-18-09, 11:45 AM
FC since 99
stylEmon's Avatar
you can have them ultra-sonic cleaned. Should be shops in the area that do it...
Old 11-18-09, 11:57 AM
Thank you for the advice all! I didn't see any easily searched threads with this topic so hopefully it will help others!
Old 11-18-09, 12:44 PM
The Doctor
g14novak's Avatar
Mods might want to tack this in the archive. Theirs some good info on cleaning and basic prep of the block in this thread (might get less people asking the same questions)
Old 11-18-09, 03:00 PM
wackaloo13's Avatar
rotors: go to autozone and buy some cold parts cleaner. let the rotors soak in this for a day or so and rinse it off with warm water. If there is any carbon buildup still there stick them back in for another day. Rinse with warm water then blast them down with some penetrating oil to prevent rust. Take a piece of old apex seal and make sure the apex seal grooves are clean and free of carbon buildup. Do the same with the side seals. Take a pick and make sure that the corner seal holes are also clean of carbon. Take a pick and make sure the oil control ring grooves are clean.
Housings: a bucket of mineral spirits and a scotch brite pad work pretty well. The inner surfaces of mine were in pretty good shape when i did my rebuild so i gave them a quick scrubbing/rinse and moved onto the sides of the housings. I first began with the scotch brite pad to get off the residual water seal. Constantly pouring the mineral spirits over it helped quite a bit to loosen things up. I then took some pretty fine sand paper and briefly sanded that area. I took a scrub brush to the outside of the parts. Make sure the dowel pin holes/oring grooves are clean. If not go to town with a tooth brush and a pick
Irons: A light scrubbing in the mineral spirits with a scotch brite pad to free up any buildup on the surface. I ground a crappy flat head screw driver down into a groove scraping tool. MAKE SURE THE GROOVES ARE CLEAN. This does take a long time but i think it is important to a quality rebuild. The outside got the brush+mineral spirits treatment. I have seen people take some 600 wet sand paper in a DA sander and lightly wet sand the surface of the irons with kerosene. I am not sure if this is advised or necessary. I did not do this on my engine.
Im sure a parts cleaner would have made the job easier but i dont have the space in my garage for one so i made do with a bucket.
Make sure that any raw iron surface gets a coating of penetrating oil to prevent rust.
This entire process does take quite a bit of time. If you can afford it i would take them to get ultra sonically cleaned or hot tanked.
Old 11-18-09, 03:49 PM
PSHH! PSHH! HEAR ME NOW?
bad 83's Avatar
If your wanting a clean hassle free finish on the housing, I always use a small brass wire wheel on a drill the clean them up. This leaves a simi-shine that you don't have to go back and polish. This is a bridgeport I built for my old SA.
Before and after pics of my 13B bridgeport I am building for my Turbo FB.
I do this with all my aluminum parts.
Old 11-18-09, 04:19 PM
Puck's Avatar
Anyone else use a sandblaster to clean the housings and irons, like I do?
Old 11-18-09, 05:18 PM
doesn't make enough money
ProChemBroTCM's Avatar
Any idea on how much that ^^ sort of thing costs?
Old 11-18-09, 05:31 PM
Compita Racing
LBC_FC3S's Avatar
500+ for the ultrasonic machine.
Old 11-18-09, 09:25 PM
Boosted. I got BLOWN!!!
beefhole's Avatar
I didn't have access at the time of rebuilding, but afterward a friend had done this for me on a scrap housing (just in case) using silica beads. It came out PERFECT.
Iron parts were easy. After a wire brush for the tough build up, I used the regular green scotchbrite pads to polish up. They came out super clean and it went pretty quick.
When I did the housings on my own, I used a dremel with the paint stripping wheels on the side surfaces. They are beige and purple (course, soft) IIRC. They practically make the aluminum into a mirror.
Old 11-18-09, 11:23 PM
rotorhead
arghx's Avatar
I cleaned my engine with a plastic tub thing and some of this "organic" cleaner stuff I got from the hardware store. but my motor didn't have 100k wor of crap on it
cristoDathird
28
05-30-19 08:47 PM
cdn
14
09-10-15 06:23 AM
cdn
2nd Generation Non-Technical and pictures
08-11-15 08:59 PM
Quick Reply: How to Clean Engine Rotors, Housings, and Irons
