Fabrication Post your questions and projects on Fabrication of Interior or Exterior or custom audio and electronics here.
Aluminized steel for exhaust piping?
Old 12-28-09, 06:05 PM
Turbo widebody FB
Dan_s_young's Avatar
Just curious if aluminized steel (16 gauge) would be ok to use for the exhaust on my 13b turbo? Any issues with the heat?
Dan
Old 12-28-09, 06:18 PM
Fabrineer
shm21284's Avatar
no. unless you want to replace it every 6 months. 304 stainless 16 ga. for downpipe and back, 321 stainless 16 ga. for manifold.
Old 12-28-09, 06:41 PM
Turbo widebody FB
excellent, thank you!
Old 12-28-09, 06:54 PM
Learned alot | Alot to go
CrackHeadMel's Avatar
I used 16 gauge for everything but my downpipe in my first two exhausts, clean the welds and spray with that zinc in a can and never had an issue with rust, or pipes rotting at all.
I dont see it being an issue at all, my next exhaust will probably have aluminized piping in it again too.
Old 12-28-09, 07:20 PM
B O R I C U A
KNONFS's Avatar
Dan
Untill the other day, all of the racing beat header\exhaust used to be made out of steel.
Old 12-28-09, 08:22 PM
Fabrineer
shm21284's Avatar
Not the turbo stuff, it was all 304. I have one in my room thats 4 years old.
The NA stuff was, and mine fell apart.
Old 12-29-09, 01:37 PM
B O R I C U A
KNONFS's Avatar
NOPE, it used to be all steel...
Also, HKS used to be steel.
Old 12-30-09, 01:33 AM
I hate drum brakes
Box_Man's Avatar
The problem with aluminized steel piping is that it is thin and it melts. It's so thin that the exhaust will resonate and make lots of noise. I have some aluminized piping in my exhaust system currently. One section, which is about 2 feet long, and just before the axle, has a big triangle shaped spot about 10 inches long where the pipe had started to melt, quite impressive, really.
Old 12-31-09, 12:07 AM
Turbo widebody FB
Very good info, thanks guys. I ordered 12 feet (more than enough) 304 stainless steel 3" piping from a local company to finish the exhaust off. Good thing I asked, I didn't realize that the rotary heat could even melt the aluminized steel.
Old 12-31-09, 01:41 PM
B O R I C U A
KNONFS's Avatar
How thin? RB uses .120
Straight from RB's website:
"Racing Beat's Road Racing Header is the first step in building a serious racing exhaust system. The engine-to-pipe flange is flame cut from 1/2-inch thick flat steel. Like all of the headers we manufacture, the Road Racing Header is constructed with 2-inch O.D. mild steel tubing, .120-inch inch wall thickness, and mandrel-bends throughout."
To the OP:
Also, the OEM exhaust system is not made of SS, is made out of steel.
Old 12-31-09, 03:32 PM
Rotor Head Extreme
t-von's Avatar
^ Yea how thin? 16g aluminized steel tubing is what I'm currently using on my NA 20b. I had an intake leak and my headers were glowing red hot at idle on more than one occasion. Seems to be holding up so far. I plan on upgrading the steel later when I re-engineer my header.
Old 12-31-09, 03:40 PM
16G to thin? If i fired up my innovate lm1 i could probably pull hours worth of dataloggs with postturbine temps of 1800+*
Only thing that melted in that exhauyst was the core to my randomtec cat, everything else survived. i even had the downpipe wrapped.
Old 12-31-09, 05:16 PM
Rotor Head Extreme
t-von's Avatar
16G isn't noisey at all on my headers. The noise I hear is at the muffler end. I'm still gonna wrap it though.
Old 12-31-09, 05:37 PM
Turbo widebody FB
The piping I ordered is 16 gauge. So hopefully that does the trick.
Old 12-31-09, 06:16 PM
STUCK. I got SNOWNED!!!!!
Terrh's Avatar
I am using SS for the header and DP on my car and aluminum (not aluminized steel, just aluminum) for the catback.
Old 12-31-09, 07:08 PM
B O R I C U A
KNONFS's Avatar
Damn, aluminum?!?!
Thats gansgta May I ask, why aluminum?
Old 01-01-10, 11:10 PM
Rotor Head Extreme
t-von's Avatar
Simple, EGT's that far back aren't nearly as hot as at the headers. Plus it's lighter.
Old 01-02-10, 12:23 AM
hose4dub's Avatar
i saw a 4 inch all aluminum exhaust from full race for a turbo civic in a book i have. pretty gnar
Old 01-02-10, 02:09 AM
Gaber's Avatar
I did made aluminum cat back exhaust for my car..
here is thread with few pics, if you know need more pics or have some question, just ask..
https://www.rx7club.com/2nd-generation-specific-1986-1992-17/pics-your-exhaust-873745/ Second post..
Old 01-12-10, 07:06 PM
I hate drum brakes
Box_Man's Avatar
To the OP:
It is 16 ga. Mild steel tubing from Summit Racing. I got it from my friend's old Jetta TDi exhaust system when he re-did his system. (it was just a temp. patch job afterall) My guess is that the pressure waves were converging in that one area of the exhaust during a high speed (and RPM) run, and heated that section of the exhaust to near failure. I don't think I'll ever do another mild steel exhaust system, stainless is too nice and durable to pass up.
Old 01-14-10, 11:56 AM
Old [Sch|F]ool
peejay's Avatar
16 gauge works just fine, have used it for years with no problems.
This is on a N/A, but N/A have hotter exhaust than turbos.
Hell my HEADERS were 16 gauge steel for a long time... no problems!
Old 01-14-10, 04:35 PM
B O R I C U A
KNONFS's Avatar
Forgot about this thread...
I know, my comment was towards why? SS is not that much more expensive than aluminum, and then there is the welding; which seems to be more expensive than SS.
Same here, well used to
