Naturally Aspirated Performance Forum Discussion of naturally-aspirated rotary performance. No Power Adders, only pure rotary power! From the "12A" to the "RENESIS" and beyond.
NA 1/4 mile times
Old 01-23-11, 09:10 PM
ultimatejay's Avatar
New time and video is in the sig. 12a power!
Old 04-30-11, 06:41 PM
lim_fc3c's Avatar
Bone stock S5 vert, 10.5 @ 62mph 1/8th mile
Old 04-30-11, 10:37 PM
What's the point??
papiogxl's Avatar
Stock S4 GXL, 1/8th mile 10.18@69mph
That was with a 2.2 60' time
Old 05-02-11, 12:23 AM
  #29
BP, Itb'ss, 10K Rpm Built
DAveFC3sNA's Avatar
14.98 , 4.3 rear 89 gtus stripped out panels interior + misc other parts, rtek tuned stock ports Rb Header straight pipe Rb exhaust apexi intake 2ndary butterfly removed, 14x7 + mickey toms from my friend, not my own tires
Old 07-13-11, 03:33 PM
  #30
MEOOOWW-cat back exhaust-
RawrZac212's Avatar
Originally Posted by s1sevennz
where can i get that tach?!
Old 07-16-11, 03:12 AM
  #31
I wish I was driving!
That's not a tach. It's measuring decibels.
Its telling you the rave starts at 9000 rpm.
Old 07-21-11, 12:31 AM
  #32
Auto Pilot
rXc3|\|tR1c's Avatar
Capella injected 13B PP 5.7 rear celica box 12.04@105
Same engine in FC with stock driveline 13.1@108
Old 07-23-11, 08:36 PM
  #33
aerosev
aerosev's Avatar
Originally Posted by aerosev
1978 s1 rx7 12a mild extend port, standard carb re-jetted, exhaust system, electronic ignition, lightened flywheel, stock wheels/tyres, series 2 LSD, series 3 gearbox
14.565 @ 92.4mph
running float bowls out of fuel after half way point
Went faster down to 14.411 heres a video of the run, the other car was a type r turbo civic.
http://www.youtube.com/watch?v=m6WdOJRh6SE
Have peripheral ported it now, its still running the original carb its making 166rwhp at the moment and 208nm torque but its now running out of breath after 7000rpm so im going to further modify the carb and see if I can get to 200rwhp on a nikki carb. Its alot faster now than what it was so hoping for 13s.
http://www.youtube.com/watch?v=oMTAlt39vUM
Old 10-07-11, 08:35 AM
  #34
aerosev
aerosev's Avatar
Went back to the dyno and got 183rwhp and 210nm torque couldn't get any more out of it as i was running out of fuel up top was dropping from 4.5psi to 2psi.
The car has a carter pump but stock fuel lines so i think the fuel lines are the restricting factor
Old 10-08-11, 11:33 PM
  #35
JZG
JZG's Avatar
Nice! Once you get the fuel delivery sorted you should be well over 200hp.
I've seen a 12A bridgeport make 220hp at the wheels running a modified nikki 4 barrel. It was in a street car with street tires and it ran a 13.4 at just over 100mph from memory.
I also know of a 13B bridgeport that made 235hp with the same carb setup.
Old 10-09-11, 02:08 AM
  #36
aerosev
aerosev's Avatar
Yeah Im sure its possible to get 200rwhp + I may put a surge tank and another fuel pump in it and go back to the dyno and see how much further I could go, but Im also tempted to just put fuel injection on it, In a way it would be simpler, However Im getting good at pulling the carb to bits to make adjustments!
Old 10-09-11, 02:12 AM
  #37
aerosev
aerosev's Avatar
Racings on the 29th so heres a video of the dyno run sorry for the shitty editing I don't know what Im doing!
http://www.youtube.com/user/aerobubb.../0/nPVmUqvnGGA
Old 10-19-11, 05:21 PM
  #38
New numbers with new 13bpp engine on TII carburetor and race gas. Better times to follow....
http://www.youtube.com/watch?v=kj93TFSq1lE
Old 10-24-11, 08:34 AM
  #39
Rallye RX7
fidelity101's Avatar
Just ran a 14.8 @ 81mph
9.5 1/8th mile
13b S5 streetport,
mikuni 44phh side draft
1st gen dizzy
gutted
full of fuel.
4.10 NA rear end
turbo trans w/ al flywheel
full exhaust
I was running 15.0 flat all day when shifting into 4th
but my trap speed was about 15mph quicker
Old 11-02-11, 10:26 PM
  #40
aerosev
aerosev's Avatar
Took the Rx7 to the strip with the new engine finally and only got two runs due to a rail car crashing and closing the strip down, had a slipping clutch but managed to run a 13.967 @ 97.52 MPH so it has got a bit more left in it yet!
the engine is a 12app with the original nikki carb somewhat modified
heres the runs from the weekend
http://www.youtube.com/user/aerobubb.../0/efQSOK0XCGI
http://www.youtube.com/user/aerobubb.../1/rxxa3H309NM
Old 11-07-11, 03:32 PM
  #41
Rallye RX7
9.5 1/8th mile
13b S5 streetport,
1st gen dizzy
gutted
full of fuel.
4.10 NA rear end
full exhaust
here are my slips and then the following week I went to the dyno, was only able to get it to 6500, 4th gear pulls take FOREVER when you need to get to 8000 rpm, heat was becoming an issue. First time on the dyno was I was a bit nervous, I buckled my seatbelt up lol.
drag times I pretty much predicted, but I was a little disappointed on the dyno pulls. I know this car is gutted to hell but it can't weight 2000 lbs
I was car 272 in the left lane each run. I'm missing a slip but its basically the same as the other 4.
Old 12-16-11, 05:09 AM
  #42
.::evil inside::.'s Avatar
I have only been drag racing once, which was in July 2010. My car is a Mazda Capella, at that stage it had a 13b bridgeport (bearings had siezed to shaft badly and free'd up again, but still dragging on the shaft, which I didn't know until the motor let go early this year - got sold a dud) fuel injected, s5t gearbox, 4.77 diff gears, guru motorsports LSD, cheap 205/60/13 tyres and a really bad speed density (map) tune done by me on the street .
I have now built a new motor for it which is leaps and bounds better, I'm running an Alpha-N (TPS) tune. While I primarily use the car for street and circuit racing, I'll run it down the strip again once it's all sorted out and I'm done running it in.
Given how badly the car was running on the speed density tune, I'm suprised I pulled out a flat 14! I'm normally not too keen on drag racing, but I'm quite interested to see how the new setup will compare.
I'm car 105 by the way
Old 02-12-12, 12:58 AM
  #43
PUTTZ's Avatar
Its a MSN Ignition Tacho, I actually stii have it, never sold it with the car, PM if your intrested.
Old 02-12-12, 01:05 AM
  #44
PUTTZ's Avatar
http://www.youtube.com/watch?v=AHiUs...3&feature=plcp
I set NZ N/A 2 rota record with this pass, a m8s car I was just driving, car was sold not too long ago, new owner put it in the wall at about 160Kph.
My old FC was post in the thread early, its the incar view.
Best pass in that was 12.2@113mph.
Sold the car and kept the motor to go into somethng alot lighter.
Old 02-20-12, 02:57 PM
  #45
spiff-d's Avatar
Honestly - 17.3 @ 88.3MPH
Spin Spin Spin - Shift, Spin Spin - Shift, Bog, down shift, catch traction, upshift.
So fantastically slow.
Old 02-21-12, 10:56 AM
  #46
IFO Forced Induction Slo
bigdv519's Avatar
My 90 vert back in 05.
Stock engine 185k miles (70ish psi).
Intake cone filter.
RB headers to straight pipe
SAFC tuned.
No AC, PS.
Stock clutch and flywheel.
Stuck closed aux ports.
Stuck closed VDI.
129rwhp IIRC.
Fastest time ever, 16.3 @ ?? mph.
Stock it ran 17.5 @ ??mph.
I recently acquired another vert and have installed a stock engine in it (105+psi)...hopefully get some numbers on it soon.
Old 02-22-12, 12:21 PM
  #47
bigdv519's Avatar
Found the old slip:
2003 at Baytown.
60' 2.402
330 7.187
1/8 11.136
MPH 61.30
1k 14.592
1/4 17.495
MPH 77.23
That's 100% stock....stuck closed aux ports.
Old 04-17-12, 02:58 AM
  #48
con-3-fc3s's Avatar
Back in 2004 my first rx7
87 fc sport 4lug
rb headers and presilencer w/oldschool sebring mufflers?
hks filter
safc2
centerforce stage2 clutch
ac and airpump removed/emissions delete
stock suspension
stock 14" wheels
full interior
212k original miles
et:14.9 @93mph 60' 2.39
Old 04-30-12, 02:09 PM
  #49
RX200013B's Avatar
mazda b2000 w/13b 6-hbp, haltech e6k. 4.07 lsd 2780lbs w/me in it.
16.001 @ 89.2mph
Old 05-07-12, 04:57 AM
  #50
jimmy13's Avatar
88 base 4 lug 195-55-16's, coilovers, 3" exhaust other then that bone stock with it barely wanting to go into 3rd gear I ran a 16.18
Quick Reply: NA 1/4 mile times
