20B RX-8 conversion...about damm time!
So here it is. I will be doing the conversion on my RX-8. Some of you know my car, others don't so here are some pics of the Renesis setup before I pulled everything out.
I plan to do the entire conversion, build, tuning etc myself just like I always build my cars. And yes it is a personal goal and challenge . I plan to take this entire year on the build so be patient. I am getting married this year and that really slows things down...hehe..don't let her hear that.
Proposed setup:
20B, Dowel-pinned, large streetport
BW S475 1.32A/R
Quickspool valve ( http://performancemetalwerkz.com/Sales.html )
4" FMIC
5" to 4" DP (car has full 4" exhaust already)
LT12s Microtech
LS2 and MSD LS2 coils
RA apex seals
3 into 1 collector manifold (like the one on the renesis but bigger)
Front subframe fabricated out of rectangular tube moving rack 2"fwd and 2"down
etc etc etc....blah blah blah..will add as needed...
Goals are a very reliable 550-600whp car at relatively low boost with a long power band to at least 82-8500rpm.(that is the reason for the large rear A/R and turbine with the no-so-large compressor)
Thanks for looking.
Chris
First version turbo kit (reached 414whp) (in production via Esmeril Racing)
100_1259.jpg?t=1264727445
My own Renesis Apex seals
Building the last manifold
First turbo Renesis half-bridge port
Proposed setup:
BW S475 1.32A/R
4" FMIC
LT12s Microtech
RA apex seals
Thanks for looking.
Chris
One new...very important part has arrived!
That is a 5 gallon pail and a 19" rim (or what's left of it...hehe...:/....don't ask...long time ago.)
I am planning my exhaust manifold. I want to do medium length runners as close as possible to equal length into a 3-1 collector right before a bend into the T6 Divided flange (quick spool valve).
What runner size do you guys recommend for each rotor? The motor will be street ported. Also, after the collector, should I do a 3" pipe to the flange or a 3.5" one?
I am planning a manifold similar to the TwinsTurbo one on their 13b but instead of going over the top of the turbo which makes it extremely long, I plan to come from the bottom like this guy:
https://www.rx7club.com/single-turbo-rx-7s-23/wastegate-runner-length-875775/
Thanks in advance.
Chris
Thanks in advance.
Chris
on
looks good!
i am interested to see the results with the quick-spool valve.
how was the boost response with the air to water intercooler?
was it not too great? i see you are going back to a fmic..
Trending Topics
Chris
If you are referring to the last Renesis setup, then yes, it would start to spool before 3500 and I could have all the boost I wanted from 4000rpm on. With the 9250redline and the short gear ratios on the RX-8, this is the equivalent of boosting by 3000 on a FD. It was a great setup. As for the 20b, Idk when it will spool but I will keep you updated .
Chris
Chris
RotorHead
on
https://www.rx7club.com/showthread.php?t=875775
Thanks in advance.
Chris
Thanks in advance.
Chris
For the quickspool valve to work you need a joined manifold where all the runners join before or at the turbo flange and you need a divided housing on the turbo. Then when the valve is closed all the exhaust goes through one of the volutes in the turbo making the speed of the gases faster than through both and when the turbo spools the valve opens to allow gases through both volutes.
I hope I didn't make it more confusing for everyone :P
Chris
RotorHead
on
Good question and you are right...maybe I wasn't clear. If you notice, the two manifolds I referenced join the runners before they reach the turbo flange. This means you do have all rotors joined when it reaches the turbo, in this case all 3 rotors, and this is good because its hard to do a divided manifold on a 3 rotor.
Chris
Chris
Just a few things that are getting ready to be put to good use.
Driver's side engine mount, will allow the 20B to bolt up to the RX-8 mount...
OEM Pass side engine mount (needs some modification but will fit the 20B onto the stock RX-8 mount.
2" SS bends for Manifold
Flanges and collector for Manifold
Assorted 4" mandrel bends for DP left over from exhaust build
Next update will be of me "going to town" on the sub-frame with a hacksaw...hehe...don't worry, I'll make it look good
Chris
Chris
on
Quick question, those guys http://performancemetalwerkz.com/Sales.html that make the quick spool valve,is it true that their out of business? just wondering if you have info?
Thanks.
Thanks.
