Tein Coilover Camber Adjustment
Old 04-19-10, 07:33 PM
K!NCH's Avatar
I was wondering how to go about it for the front of my FC? Car on the ground or off? And it is just the bolts on top of the coilover? I did some searching on google; but since the FC is different, then say a 240, I was wondering if there's anything special I need to do. A write up would be great.
I only plan to add 1 degree of negative camber, will need a full alignment afterwards? Thanks.
Old 04-19-10, 07:46 PM
Slowpoke
Hypertek's Avatar
camber plates? lift the front of the car off the ground and push em.
Old 04-19-10, 07:48 PM
Are you experienced?
jjcobm's Avatar
You would need to have the wheels off the ground since it would be difficult to adjust the strut with all the weight of the car sitting on it. Changing camber will change your toe so keep that in mind.
To do a proper alignment you would have to check your toe afterward.
I have found this guy is very accurate and informative its a 3 series video:
www.youtube.com/watch?v=sZoL1gaWedA
Then read this:
http://home.comcast.net/~jkrane/susp...y/susp401.html
And you should be set if you feel like taking on the work.
Old 04-20-10, 11:09 AM
K!NCH's Avatar
So what if I just adjusted them at the track and then put them back to how they were for the street?
Old 04-20-10, 03:19 PM
Fistful of steel
LargeOrangeFont's Avatar
As you add negative camber you will add toe out.
Old 04-20-10, 05:10 PM
K!NCH's Avatar
Right, but if I do it on the track. Then set it for street will it be the same as I had it before the track?
Old 04-20-10, 05:13 PM
Captain OCD
SoloII///M's Avatar
If you mark the position first it will be very close to where it was before you moved it.
Old 04-20-10, 05:18 PM
K!NCH's Avatar
That's what I needed to know. Thanks!
Old 04-20-10, 10:35 PM
Fistful of steel
So have the car set for a bit of toe in with little to no negative camber for the street. Then when you go to -1 degree camber you will have a little bit of toe out.
Old 04-21-10, 08:40 AM
Irentat's Avatar
Toe is always adjusted/checked last after any adjustment is made to anything else.
I learned to do toe, camber, caster, SAI measurements and adjustments all on my own.
Ernstudet22
09-14-15 09:19 PM
Quick Reply: Tein Coilover Camber Adjustment
