stock 20b in fd3s
FD3S 20B
on
stock 20b in fd3s
hey i have a complete standard tt 20b front cut which I am building into my fd3s but am having trouble with the wiring so I can not start the engine.
http://img25.imageshack.us/i/03042010003.mp4/
http://img249.imageshack.us/i/05042010004.mp4/
FD3S 20B
on
can i use stock fd wiring harness or the cosmo harness ?
i dont know what to do but if somebody have the wiring diagram in english for the 20b it will help a lot or can tel me what to do thanks
watashi no shichi
What specifically do you need help with in terms of wiring?
Give a little more detail in terms of what ECU you're using, etc etc.
If you kept the 20B engine harness then you could get as simple as running an AEM for a PNP option (you'd need to swap a few pins around).
FD3S 20B
on
can i use all the FDs fuse boxes or do i need to swap it all with the cosmos fuse boxes and wiring.
its all standart and its all there stock ecu, ignition, wiring etc etc i just want to run it in my FD as a stock 20B Twin Turbo
Received 2,565 Likes
on
basically with the stock 20b ecu, you need a portion of the cosmo dash and body wiring. the easy way would have been to get it running with no error codes (a half cut will have a limp home error code), and see what you can eliminate from the cosmo harness to put in the FD.
the car was never exported from japan, so there are no factory manuals in anything but japanese.
we put a 20b into a b2600 truck, so it needed a couple of fuseboxes from the cosmo, but i suspect the FD and cosmo actually have similar ones, give or take
FD3S 20B
on
oka i then need the japanese wiring diagram can somebody send it to my mail ? thanks.
furious-imports@hotmail.com
on
Does anyone know the pinouts from the engine loom to the body loom of the 20B?
I too will be using a stock 20B and management system in my FD and need to know what wires to connect to my FD loom.
Thanks
Chris
Thanks
Chris
Trending Topics
FD3S 20B
on
got it all working
stock cosmo wiring + ecu for only the engine
apexi power fc + fd wiring for the fd elektronik
now i only need the pipes fixt
testing:
video 1: http://tinypic.com/player.php?v=2dbm269&s=4
video 2: http://tinypic.com/player.php?v=2n69bw0&s=4
video 3: http://tinypic.com/player.php?v=2j2aupx&s=4
FD3S 20B
on
FD3S 20B
on
Hmm i cant remember but i think i used the stock 20B wiringharness + the 13B wiringharness, my stock twin turbos needed a rebuild so i desided to go single. >But i remeber it ran perfekt with no faults.
FD3S 20B
on
found some old videos with the stock twins and power fc
http://tinypic.com/player.php?v=28auy42&s=7
FD3S 20B
on
i have gone Single so i cant remember it all. (you can click on my name an see engine picture)
But you need to get a frontcut that will start the engine, an you can then show me the wires from one of the white plugs where the ECU is an i can tell you what plugs you need and what you dont need
