idle problem
Old 05-31-10, 04:31 PM
rotary power bitch
ziereisboy91's Avatar
idle problem
ok few questions
one, i removed my blue nasty looking filter and put a nice chrome one on that shows the air filter, but now im having idling problems, it wont idle down after i let off the gas from driving it stays at 1500rpm, ive plugged the coast valve and idle compensator. i have adjusted the air mixer screw were it drops to 750 rpms and it stays running fine, once i start driving the car it stays up at 1500 rpms, unless i pull the choke out and release it then it will drop down to 750rpm. i have the dizzy hooked up the the second nipple on the carb from the front of the car back.
anyone have any idea on what could cause this problem, i have all emission unhooked but not removed its an 84 rx7 gsl with a 85 gs 12a motor in it 5 speed
Old 05-31-10, 07:48 PM
Fighting Global Cooling
FunK73's Avatar
Have you checked the operation of your choke? Since you say it drops to normal idle after you play with the choke pull it sounds like maybe its sticking closed slightly
Old 05-31-10, 08:57 PM
1st-Class Engine Janitor
DivinDriver's Avatar
One of the little hoses from the blue air cleaner, the one with the thermostat-looking gizmo inside the cleaner, is called an "Idle compensator." You need to plug that hose where it enters the ratsnest, else you have a nice vacuum leak, which raises your idle.
Old 06-01-10, 09:34 AM
rotary power bitch
i have the idle compensator plugged
ill look at the choke deal
Old 06-01-10, 09:54 AM
rotary power bitch
would the dashpot rod getting caught up cause it to do that
Old 06-01-10, 10:50 AM
Yep; dashpot's job is to slow engine decel. If it sticks, you don't get quite all the way back to idle.
Old 06-01-10, 11:37 AM
Old Fart Young at Heart
trochoid's Avatar
Repaint and install the oem air cleaner, that will solve you're problem.
Old 06-02-10, 12:19 PM
rotary power bitch
ok im running lean, ive been trying to adjust the air fuel mixture, but im not sure witch way the air goes to reduce it, ive turned it 1 full turn counter clockwise it that more fuel, or more it, im not quiet sure. anyhelp
barkz
Power FC Forum
37
11-21-20 09:34 AM
09-16-18 07:16 PM
ZacMan
09-19-15 09:20 PM
firzen
09-15-15 12:04 PM
rx7shirley
09-02-15 02:11 PM
Quick Reply: idle problem
