Rotary Drag Racing The place to post your racing stories and info
msd digital 6 wiring help
Old 02-02-11, 08:13 PM
It's finally reliable
MOBEONER's Avatar
Ok fellas i need some help wiring my msd to stock leading coil. I have been browsing around but all i can find are ford wiring diagrams. I drew up a picture of how i think its supposed to be wired. I would also like to know where the pink wires goes to.
black/red coil side to MSD black wire
yellow/red coil side to MSD orange wire
black/red harness side to MSD white wire
yellow/red harness side to MSD red wire
blue wire is two step <-- still trying to figure out hot to wire this
pink wire goes to????
I was trying to use this wiring diagram but not sure if its correct.
Old 02-02-11, 08:37 PM
legion's Avatar
i dont think you can wire the two step b/c it will not cut the spark to the trailing coils. i also think the pink wire is used as a trigger for the two step.
Old 02-02-11, 08:41 PM
MOBEONER's Avatar
yes the two step gets two relays wired into a switch to cut the trailing off. Any Ideas on how all that is wired up?
Old 02-02-11, 08:52 PM
legion's Avatar
found this may help
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/msd-6al-2-step-install-instructions-910963/
Old 02-03-11, 01:07 AM
7s before paint!!!
13B-RX3's Avatar
Pink is the retard function. You apply ground or 12V (depending on the model) to activate the two step (Blue wire).
This should help.
http://www.msdignition.com/uploadedF...structions.pdf
I wouldn't use any of the factory wiring to the MSD other than the trigger wire. Run the power and ground leads straight to the battery.
Old 02-03-11, 09:39 AM
Chasing numbers
sk8world's Avatar
Search for Vikings old write up on this. Also trotts did a nice write up last year for this plus relays to kill trailing along with line lock. Believe there was a link off that thread for mad wiring.
Old 02-03-11, 04:11 PM
MOBEONER's Avatar
I believe them write-ups where for 6AL. I was under the impression that the 6al and digital 6 where different colored wires.
Old 02-03-11, 06:05 PM
Chasing numbers
sk8world's Avatar
I am not sure on the color codes..
Old 02-04-11, 07:57 AM
MOBEONER's Avatar
Ok coils are hooked up. Now my question is, does the pink wire (retard function) gets hooked to anything or do we not use this function on our cars? I read in some other forums that guys use the pink wire on throttle for nitrous Injection but I am only running water injection so I would assume the pink wire does not get used.
DocHoliday89
10-12-15 07:42 PM
foxbod88
09-23-15 09:07 AM
gxl90rx7
Haltech Forum
09-14-15 03:09 PM
Quick Reply: msd digital 6 wiring help
