Build Threads The place for complete build threads of 1st Gen RX-7s.
1985 RX7 Single Turbo Build...
Old 04-15-11, 10:10 PM
35r 13b first gen
zaridar's Avatar
I bought this car when I was 17 in 2001 I believe. I drove it as it was for a while not knowing what it really was... Over the last few years I have really started to build it. I am going to go through my pictures and try go through what all did to it as best as I can.. IF anyone can explain how to get photos to appear in the thread let me know please...
This is what she was when I started...
Old 04-15-11, 11:15 PM
35r 13b first gen
zaridar's Avatar
IT was a bit rusty when I got it..... I put on KYB shocks, new tie rod ends pitman arm, idler arm, brakes.... swapped the rear end for an LSD and disc brakes... sandblasted and repainted the rear end and drive-shaft as well as the strut assemblies...
Attached Thumbnails 1985 RX7 Single Turbo Build...-pict0345.jpg   1985 RX7 Single Turbo Build...-pict0357.jpg   1985 RX7 Single Turbo Build...-pict0359.jpg   1985 RX7 Single Turbo Build...-pict0360.jpg   1985 RX7 Single Turbo Build...-pict0366.jpg
Old 04-15-11, 11:16 PM
35r 13b first gen
zaridar's Avatar
new stuff
Attached Thumbnails 1985 RX7 Single Turbo Build...-pict0470.jpg   1985 RX7 Single Turbo Build...-pict0483.jpg   1985 RX7 Single Turbo Build...-pict0485.jpg   1985 RX7 Single Turbo Build...-pict0490.jpg   1985 RX7 Single Turbo Build...-pict0491.jpg
Old 04-15-11, 11:18 PM
35r 13b first gen
zaridar's Avatar
and more
Attached Thumbnails 1985 RX7 Single Turbo Build...-pict0492.jpg   1985 RX7 Single Turbo Build...-pict0493.jpg   1985 RX7 Single Turbo Build...-pict0494.jpg   1985 RX7 Single Turbo Build...-pict0499.jpg   1985 RX7 Single Turbo Build...-pict0500.jpg
Old 04-15-11, 11:20 PM
35r 13b first gen
zaridar's Avatar
bent new brake lines and ss braided hoses, and new rear brake cables...
Attached Thumbnails 1985 RX7 Single Turbo Build...-pict0573.jpg   1985 RX7 Single Turbo Build...-pict0574.jpg   1985 RX7 Single Turbo Build...-pict0575.jpg   1985 RX7 Single Turbo Build...-pict0577.jpg   1985 RX7 Single Turbo Build...-pict0576.jpg
Old 04-15-11, 11:23 PM
35r 13b first gen
zaridar's Avatar
old engine bay... and my buddy ricky
Attached Thumbnails 1985 RX7 Single Turbo Build...-pict0578.jpg   1985 RX7 Single Turbo Build...-pict0581.jpg   1985 RX7 Single Turbo Build...-pict0585.jpg   1985 RX7 Single Turbo Build...-pict0587.jpg   1985 RX7 Single Turbo Build...-pict0590.jpg
Old 04-15-11, 11:24 PM
35r 13b first gen
zaridar's Avatar
mom dad myself and my first engine pull...
Attached Thumbnails 1985 RX7 Single Turbo Build...-pict0597.jpg   1985 RX7 Single Turbo Build...-pict0598.jpg   1985 RX7 Single Turbo Build...-pict0602.jpg   1985 RX7 Single Turbo Build...-pict0604.jpg   1985 RX7 Single Turbo Build...-pict0605.jpg
Old 04-15-11, 11:29 PM
35r 13b first gen
zaridar's Avatar
switching stuff to new engine.... 12a Streetported...
Attached Thumbnails 1985 RX7 Single Turbo Build...-pict0613.jpg   1985 RX7 Single Turbo Build...-pict0621.jpg   1985 RX7 Single Turbo Build...-pict0616.jpg   1985 RX7 Single Turbo Build...-pict0618.jpg
Old 04-15-11, 11:32 PM
35r 13b first gen
zaridar's Avatar
new engine in its home with new AZ alternator and hoses... thats enough for tonight. this all was in the summer of 2006 when I returned home from korea...
Attached Thumbnails 1985 RX7 Single Turbo Build...-pict0635.jpg   1985 RX7 Single Turbo Build...-pict0636.jpg   1985 RX7 Single Turbo Build...-pict0637.jpg   1985 RX7 Single Turbo Build...-pict0638.jpg   1985 RX7 Single Turbo Build...-pict0640.jpg
Old 04-16-11, 12:08 AM
Rotory United RU.
acekid7's Avatar
insane man, cool pic's.
Old 04-16-11, 04:37 AM
Round and Round
74RX4's Avatar
After you have uploaded your attachments, links for each one appear on the posting page. Scroll down to the attach files section in the Additional Option area. Right click on the link and copy the link location. Paste this link into your message with the image tags surrounding it. [img] in front of the link and [/img] after it.
Old 04-16-11, 03:19 PM
rxtasy3's Avatar
u can also upload ur pix to photobucket.com. it generates the image code to post into threads then they show up in the post rather than a clickable pic for the larger view.
Old 04-16-11, 05:54 PM
35r 13b first gen
zaridar's Avatar
Rebuilt the carb... pics of teardown
Attached Thumbnails 1985 RX7 Single Turbo Build...-pict0674.jpg   1985 RX7 Single Turbo Build...-pict0678.jpg   1985 RX7 Single Turbo Build...-pict0680.jpg   1985 RX7 Single Turbo Build...-pict0719.jpg   1985 RX7 Single Turbo Build...-pict0716.jpg
Old 04-16-11, 06:05 PM
35r 13b first gen
zaridar's Avatar
MSD Coils.. Pulled motor again... front torington bearing dropped while installing dual belt pulley setup from RB. Make sure you have your assistant keep the clutch held in until the pulley is completely in place... haha. Also put another used tranny in it.. got mine rebuilt... at first it didnt have 5 and R so i had to take it back out and back to the shop.. then after i got it back i lost 3 and 5 after about 3000 miles... so i just stuck a used one in it from a parts car... this one lasted me tons of abuse and up till this last fall... starting to grind now.. can hold up to the turbo.... i will get to that here soon... also installed a centerforce dual friction clutch which was awesome... until turbo...then started to slip... i got pics here somewhere
[img]https://www.rx7club.com/attachment.php?attachmentid=426521&stc=1&d=1302994 944,
https://www.rx7club.com/attachment.php?attachmentid=426522&stc=1&d=1302994 944[/img]
Attached Thumbnails 1985 RX7 Single Turbo Build...-pict0053.jpg   1985 RX7 Single Turbo Build...-pict0057.jpg   1985 RX7 Single Turbo Build...-pict0170.jpg   1985 RX7 Single Turbo Build...-pict0180.jpg   1985 RX7 Single Turbo Build...-pict0164.jpg
Old 04-16-11, 06:14 PM
35r 13b first gen
zaridar's Avatar
New clutch, dual belt setup on with gatorback belts, RB Ultra wires, new AZ slave, ss braided clutch line, new AZ trans mount, new mazdatrix OMP and lines, new coolant temp switch/sensor.. not sure which one it is.. the yellow wired one in the water pump...
Attached Thumbnails 1985 RX7 Single Turbo Build...-pict0074.jpg   1985 RX7 Single Turbo Build...-pict0077.jpg   1985 RX7 Single Turbo Build...-pict0078.jpg   1985 RX7 Single Turbo Build...-pict0079.jpg   1985 RX7 Single Turbo Build...-pict0080.jpg
Old 04-16-11, 06:20 PM
35r 13b first gen
zaridar's Avatar
Ready to go back in.... like my dads custom riding stow plow/grader... haha.... all new energy suspension bushings(helped a ton! way less body roll) only got a pic of the sway bar links tho.. did the 4 link, watts, stay rods or whatever they are called.. sway bar braket bushing and link kits...
Attached Thumbnails 1985 RX7 Single Turbo Build...-pict0081.jpg   1985 RX7 Single Turbo Build...-pict0083.jpg   1985 RX7 Single Turbo Build...-pict0084.jpg   1985 RX7 Single Turbo Build...-pict0093.jpg   1985 RX7 Single Turbo Build...-pict0096.jpg
Old 04-16-11, 06:23 PM
35r 13b first gen
zaridar's Avatar
back in its home... starting to look semi nice....
Attached Thumbnails 1985 RX7 Single Turbo Build...-pict0103.jpg   1985 RX7 Single Turbo Build...-pict0104.jpg   1985 RX7 Single Turbo Build...-pict0105.jpg   1985 RX7 Single Turbo Build...-pict0106.jpg
Old 04-16-11, 06:27 PM
35r 13b first gen
zaridar's Avatar
blackdragon auto euro style headlights and heavy duty headlight wiring harness... have HIDs now but not yet installed... these are nice looking and fairly bright however compared to stock...
Attached Thumbnails 1985 RX7 Single Turbo Build...-pict0099.jpg   1985 RX7 Single Turbo Build...-pict0100.jpg   1985 RX7 Single Turbo Build...-pict0101.jpg   1985 RX7 Single Turbo Build...-pict0107.jpg   1985 RX7 Single Turbo Build...-pict0109.jpg
Old 04-16-11, 06:29 PM
35r 13b first gen
zaridar's Avatar
Thanks for the info guys!
Old 04-16-11, 09:03 PM
Round and Round
74RX4's Avatar
Nice job. The BD relays that came with my kit last year were not sealed. The contacts rusted in short order. Most auto parts stores have sealed relays that plug right in.
We are waiting for the turbo
Old 04-16-11, 09:38 PM
35r 13b first gen
zaridar's Avatar
thanks... yeah my car sat in the garage at my parents and my relays corroded up... i didn't get new sealed ones from work yet but after this winter in the garage that is not heated all the time i might have to do that thanks.... the turbo is coming...
Old 04-19-11, 12:03 AM
35r 13b first gen
zaridar's Avatar
next i believe(not 100% sure on the order of all of this) i put on the 47 OER Japanese racing carb. this is basically a work-alike of a weber. it actually is fitted with Webber idle main jets and e tubes. Also I installed the one piece intake manifold.... Since I installed the carb, I have kind of had a flat spot and haven't gotten it tuned 100% This did add a great deal of acceleration however.
Attached Thumbnails 1985 RX7 Single Turbo Build...-pict0822.jpg   1985 RX7 Single Turbo Build...-pict0823.jpg   1985 RX7 Single Turbo Build...-pict0824.jpg   1985 RX7 Single Turbo Build...-pict0825.jpg   1985 RX7 Single Turbo Build...-pict0826.jpg
Old 04-19-11, 12:06 AM
35r 13b first gen
zaridar's Avatar
Also I made my exhuast. This was the first time.... 2.5" mild steel, flowmaster super 40 underneath and an ebay stainless with 5" tip on the rear.... This was before I got the MIG conversion kit for my dads welder. MIG is so much nicer!!
Attached Thumbnails 1985 RX7 Single Turbo Build...-pict0827.jpg   1985 RX7 Single Turbo Build...-pict0828.jpg   1985 RX7 Single Turbo Build...-pict0829.jpg   1985 RX7 Single Turbo Build...-pict0830.jpg
Old 04-19-11, 12:10 AM
35r 13b first gen
zaridar's Avatar
this is how she was sitting in OCT 08... Got one loud exhuast ticket with it... the flowmaster is way too loud... That exhaust is now for sale.... I did get the ticket dropped due to having hobbyist plates... kinda like collector plates but for modified vehicles
Attached Thumbnails 1985 RX7 Single Turbo Build...-pict0831.jpg   1985 RX7 Single Turbo Build...-pict0832.jpg   1985 RX7 Single Turbo Build...-pict0833.jpg   1985 RX7 Single Turbo Build...-pict0834.jpg
Old 04-19-11, 12:15 AM
35r 13b first gen
zaridar's Avatar
OH and you can notice at some point in there i removed my trim and shaved down the marker lights so they have a lower profile... also at some point i attempted to paint my hood.... it turned out all right but i didnt sand it smooth enough in some spots and must have had some oil residue or silicone residue on the corner because it had small imperfections and fish eyed.. however it looks much nicer than the rusty and faded hood...
Attached Thumbnails 1985 RX7 Single Turbo Build...-pict0684.jpg   1985 RX7 Single Turbo Build...-pict0674.jpg   1985 RX7 Single Turbo Build...-pict0675.jpg   1985 RX7 Single Turbo Build...-pict0676.jpg
Quick Reply: 1985 RX7 Single Turbo Build...
