Custom Gauge Cluster?
Old 07-07-11, 01:58 PM
Remove this account
cyberxn's Avatar
Question Custom Gauge Cluster?
Is there a place online that has Pre-cut dash pieces that will replace the cluters set and let you fit Autometer Gauges? or other Aftermarket one's?
reason i ask is i will be doing a 350 swap here soon and wanted to redo the dash..
Engine and trans will be up for Grabs soon as well
Old 07-07-11, 02:17 PM
Rotary Revolutionary
sharingan 19's Avatar
http://motors.shop.ebay.com:80/Cars-...t&Model=Camaro
Best bet...
Old 07-07-11, 02:28 PM
Remove this account
cyberxn's Avatar
lost me.. the dash from these?
Old 07-07-11, 02:51 PM
Slowpoke
Hypertek's Avatar
he meant get a camaro and put the 350 in..
You got to custom make one yourself.
Im not a fan of autometer gauges in a japanese car.
Old 07-07-11, 03:03 PM
Remove this account
cyberxn's Avatar
i was useing it as an Exsample any idea what size the gauge holes are on the 89's an up with the Round setup
Old 07-07-11, 03:17 PM
Rabbit hole specialist
JerryLH3's Avatar
They are small, approximately 45 mm. Your best bet is to grab some ABS and start cutting if you want a complete custom setup. I believe some manufacturers make 45 mm gauges, so you could just hollow out the stock cluster and put some in.
Old 07-07-11, 03:37 PM
Cake or Death?
clokker's Avatar
If you're going full custom, I'd use Speedhut gauges over Autometer.
Many of the 2nd gen swappers keep the stock cluster but replace the mechanical speedo with an electronic one from an Acura (which is apparently a very easy swap).
In that case, Digital Dakota boxes are used for both the speedo and tach to get proper readings.
One of the best swaps I've seen used the gauge cluster from the donor Camaro- he did some very nice plastic work to meld the stock bezel to the new gauges.
No matter what, the fuel level gauge is going to be the tough one...Mazda is backasswards from most other cars and almost anything but stock is difficult to get right.
Old 07-09-11, 10:00 AM
Why? Why?? WHY???
DBookatay's Avatar
Couldnt you just replace the sender as well?
Old 07-09-11, 10:08 AM
FC guy
Rob XX 7's Avatar
check out speedhut gauges, all custom and in my opinion look better then any jap or domestic gauges
Old 07-09-11, 08:04 PM
Cake or Death?
clokker's Avatar
Yes, I suppose you could.
Old 07-10-11, 08:56 PM
POWERRR
86mazdafc's Avatar
before you install the dash please take measurements...it would be alot of help people
Old 07-11-11, 07:55 AM
JerryLH3's Avatar
What do you specifically need measurements of? My whole car is apart, so I could conceivably accomplish that task.
Old 07-11-11, 09:09 AM
FC guy
Rob XX 7's Avatar
this is the thread that got me thinking speedhut gauges for the winter
I like the stock look but always wanted something better, and to get rid of the smaller gauges in my car, gps speedo is really cool, especially for the t56 swap guys
https://www.rx7club.com/interior-exterior-audio-26/cluster-issues-my-solution-speedhut-gauges-retro-fit-959423/
Old 07-11-11, 01:26 PM
JerryLH3's Avatar
That's very sharp looking. To me, something like that looks right at home in an FD. I always picture the FC as more of a 1980s thing, which something like that almost looks too modern to me for an FC.
Old 07-11-11, 01:41 PM
FC guy
Rob XX 7's Avatar
the gauges are customized, point is they look stock, not aftermarket especially because the brand of gauge is not plastered across the front of it
Old 10-10-11, 12:31 PM
Remove this account
cyberxn's Avatar
OoOooO i like that, very sharp indeed
Old 10-10-11, 01:01 PM
Rotary Zealot!
Derekcat's Avatar
Originally Posted by sharingan 19
+1 ^_-
Prosport 45mm Amber series gauges fit pretty nicely [search]
Old 11-28-11, 05:40 PM
Remove this account
cyberxn's Avatar
Any idea the Sizes for the Speedo and Tach?
Old 11-28-11, 05:58 PM
Sharp Claws
RotaryEvolution's Avatar
seriously
pull the dash out, pull the gauge cluster off and take your own measurements. if you need to ask...
want someone to cut the holes for you too?
Old 11-28-11, 06:10 PM
Remove this account
cyberxn's Avatar
no i just lack the means of getting a proper Measurement.
not getting any tonight or something? no need to act like that for a simple Question
Old 11-28-11, 06:13 PM
Remove this account
cyberxn's Avatar
AND i dont have the dash as of Yet, just got one off Ebay. and waiting
Old 11-28-11, 06:14 PM
Sharp Claws
it's a simple job. not nearly as complicated as gutting an engine bay, fabricating mounts, modifying a hood, adapting drivelines, running wiring, etc, etc, etc.
most smaller gauges are 52mm or you can get them as small as 45mm which is about as good as it gets for the fuel, oil and temp gauges. the tach is 112mm and the speedo is 94mm.
want me to convert that into inches for you?
by the way, most people make their own blank, cut it to whatever size they need and put whatever gauges they want into that. the question is also pretty vague. maybe you want a CAD drawing of the exact opening size so you can fit as many gauges as possible?
Old 11-28-11, 06:17 PM
Remove this account
cyberxn's Avatar
Congrats on being a world leading ******* i don't need your ****, Thanks for the help
how anyone can work with a dick like you is WAAAAY beyond me. Im out
Old 11-28-11, 06:18 PM
Sharp Claws
bye
Old 11-28-11, 06:48 PM
Driving RX7's since 1979
HOZZMANRX7's Avatar
With that attitude, DO let the door hit you in the a-ss on your way out.
Quick Reply: Custom Gauge Cluster?
