Mickey Thompson 26x11.5-16 & 26x10.5-16 ET Streets vs 255/50R16 ET Radials sizing
Has anyone tried the fitment for the three different tires?
I know for certain the 255/50/16 Mickey Thompson ET Street II Radials fit the stock wheels and rear quarters with no modification on a lowered car but will rub the top of the wheel well if too low.
I want to know if the 26x11.5-16 ET Street bias-ply tires will fit under the quarters as well. The dimensions are very similar to the 255/50/16 Radials and are even the same model# under Mickey Thompson's site but just have a R designating the radial tire.
The dimensions are posted below. What do you guys think? Does anyone have experience with it? Maybe some pictures? Thanks a ton guys. Oh and sorry if this is a repost, I haven't found anything (maybe bad searching).
Model# 3792
Tire Size 26 x 10.50-16
Wheel Diameter 16 in.
Sidewall Style Blackwall
Tire Construction Bias-ply
Directional No
Tire Diameter 25.90 in.
Section Width 10.30 in.
Tread Width 8.40 in.
Technically a 255/50/16
Model# 3793
Tire Size 26 x 11.50-16
Directional No
Tire Diameter 26.20 in.
Section Width 10.80 in.
Tread Width 9.70 in.
Technically a 275/50/16 although they're similar in size as the radials 255/50/16
Model# 3793R
Tire Size 255/50-16
Tire Construction Radial
Directional Yes
Tire Diameter 26.00 in.
Section Width 10.50 in.
Tread Width 9.60 in.
Model# 3792
Directional No
Model# 3793
Directional No
Model# 3793R
Tire Size 255/50-16
Directional Yes
4th string e-armchair QB
on
FD or FC?
I have the 26x11.5x16 ET streets mounted to FD rims on the back of my FC with a spacer. All they needed was a pull/roll on the fender. I'm quite sure others have had them on an FD without a problem. The 26x11.5x16 measure just aroud 10" in tread, and fit pretty much identically as my 275/40r17 street tires (not DR's though). Never tried the 255 DR's, but I'd go with the 275's if you want to go radials. However, if you are using stock FD wheels, go with the ET Streets, not only are they better for launching at the track, but I'm not sure DR's would maintain a nice flat contact patch on an under-sized wheel vs. the bias-ply tires.
www.lms-efi.com
The long story...
The car is using an ACT light flywheel. The heavier of the two they offer. We've launched the car at 8k with 18psi and it either bites and goes (decently) or bogs. Even when it does not completely bog, the best 60 ft times are 1.6s. Nothing to write home about. From discussions I've had with a few people, it seems the inertia of a much heavier flywheel would help us here. Either that, or a smaller tire (less bite). Once it's passed 60 ft, that big, heavy tire is pretty much along for the ride anyway.
Trending Topics
i would go with 10.5's. i run them and have pretty consistent 60' times. i have talked to people that have run them both and unless your car has alot of power, you should stay away from the 11.5's. many have reported slower 60' times with the 11.5's but again it depends on your set up.
www.lms-efi.com
We've been side stepping the clutch. Car has only made maybe a dozen passes, so there's still a learning curve going on. But the situation is pretty obvious. I added a Tilton valve this year, but we haven't had a chance to test. Should be back out next spring to give it a try. I'm hopeful that it will help alot. I think a different flywheel, the Titlton valve, and the 11.5s will ultimately be a good combo. But what we have now is just not working.
Chasing numbers
I would just stay with the 10.5's. I was able to cut a best of 1.36 on them and that was free revs, no 2 step. Stock springs/struts, stock axles, TII diff. I am very confident they have much more in them.
Also dont be fooled.. A 11.5 tire on a 15 inch wheel (pic above) is differant than a 11.5 on a 16 wheel. Way more side wall!
By the way, nice pics C. Ludwig!
www.lms-efi.com
Thanks. Wish it was my car. It looks the part. Just need to make it go like it should. Not quite the sum of it's parts yet.
1262@54psi
[QUOTE=C. Ludwig;10858116]The 11.5s will fit. Required some careful choice of wheels. That said, this car is in the 700hp range and I feel that the 11.5 is too much tire for it.
QUOTE]
Could i ask whats the width and backspacing of those wheels, Im looking for a set of rear wheels for my fd
QUOTE]
I figured I would post a follow-up now that I have some tires. The 11.5's fit on stock wheels almost exactly like the 255/50R16 Street Radials do. They don't leave much room for expansion but they fit great. I attached some fitment pictures. It's a dark cloudy day so it's kind of hard to get a good shot with my phone.
Looks like they are too big...
Side by side reference with the 255/50R16 (Right) and the 26x11.5x16 (Left).
Fitment is close but it works.
This is what happened to my old tires. Blew out at around 80mph, still no idea why.
09-16-18 07:16 PM
[For Sale] Scratch & Dent, Used, and Open-Box Sale!
SakeBomb Garage
Vendor Classifieds
08-09-18 05:54 PM
rx8volks
Canadian Forum
09-01-15 11:02 PM
