What did you do to your FB today?
Old 08-18-12, 07:23 PM
  #1176
Old [Sch|F]ool
peejay's Avatar
The one coming out had a big split up the bottom back. Not sure how a crack could form THERE, but okay. Thus the brace on the one that went in.
Old 08-19-12, 10:09 AM
  #1177
euler's Avatar
Originally Posted by aws140
Cleaned up the wiring from all my recent work, gave a quick bath, and drove it for the first time in about a year to a local car show. I really need to make this DDable.
I'm jealous, it looks really nice.
Old 08-19-12, 04:14 PM
  #1178
Duke of Hiroshima
BrGreenSA's Avatar
washed it, drove it around a bit for no particular reason, and stopped and looked at a 4 door chevy nova as a potential project for me and the gramps.
Old 08-19-12, 09:46 PM
  #1179
Don't Cross The Streams..
Rotor_Venom08's Avatar
TX
attempted to rebuild all my calipers and install new rotors. only failed.. rear rotors i got from oriellys, i believe brake bests. dont fit.... there for an 85 gsl which i have SO WTF! im loosing my mind.. they have this lip on the inside and wont fit all the way on the axel.. tried sanding the lip and banging them on even tightening them with the lugs, nothings worked, going to go get my money back tomorrow and get the beck and arnleys.
anyone ever had this problem?
Old 08-20-12, 02:30 AM
  #1180
premix, for f's sake
Sgt.Stinkfist's Avatar
i thought about my girl...sitting in the underground garage of the apartment across the parking lot, un-touched for 2 days, while my other girl sleeps on the couch next to me, but to make it up... the first girl is gonna get a pair of Mitsubishi Lancer EVO9 fuel injectors for her b-day ( i still have 9 months to figure out what the other girl is gonna get for her b-day... i bet she'd be ****'d if i gave her the other pair of evo injectors )
Old 08-20-12, 10:03 AM
  #1181
1st-Class Engine Janitor
DivinDriver's Avatar
She's been sitting under a car cover this week; woodworking project underway in the garage, and the hampsters hate the taste of oak dust.
Hopefully back on -7 work around mid-week. Less than a month to the first car show she'll make this year (JCCS).
Old 08-20-12, 10:08 AM
  #1182
Kaaarl12a's Avatar
Ran autox 75.07 seconds... I'm not the slowest....
Old 08-20-12, 10:37 AM
  #1183
RAWR
OneRotor's Avatar
Started my fight against cancer:
https://www.rx7club.com/1st-generati...egins-1008856/
Old 08-20-12, 01:20 PM
  #1184
Duke of Hiroshima
BrGreenSA's Avatar
waiting right now for my a/c to be retrofitted to r134, cant stand this summer heat any longer, it must be starting to get to me, as i'm having impure thoughts of shoehorning a 6.1 hemi that someone i know has sitting in their garage in an SE shell..... please forgive me rotary gods, for i have sinned....
Old 08-20-12, 01:23 PM
  #1185
死*神*
dream36realms's Avatar
here she is currently
Old 08-20-12, 01:39 PM
  #1186
Duke of Hiroshima
BrGreenSA's Avatar
that is one sexy looking car you have there man! i like how you retained the funky rx-7 decal on the header panel, very cool!
Old 08-20-12, 03:10 PM
  #1187
n00b
jeg0024's Avatar
Oh damn, I want those flares and that lip
Old 08-20-12, 04:05 PM
  #1188
Your brain on triangles..
Jingkun's Avatar
I want that nose panel lol I finished fixing my wipers today. The drive arm bushing came off a few months back and since then the wipers wouldn't go all the way up or back down with out me pushing them down. Pulled the whole motor and arm assembly and checked the bushing to find it cracked... well a little jb weld fixed that and it works great again.
Old 08-20-12, 04:55 PM
  #1189
Oldschool
Redliner223's Avatar
Took a friend to the movies in the -7, I will saw we both had a blast and Expendables 2 is a badass movie.
Old 08-20-12, 07:15 PM
  #1190
HeyHeyHey..Its the Goose
Qingdao's Avatar
Sationary bearings/rotor bearings on the way from Mazdatrix.
I'm gonna get this sucker put together damn it!!!!
Old 08-20-12, 08:53 PM
  #1191
euler's Avatar
I made a small bracket to hold the pressure switch and relay for the methanol/water pump. They were previously zip tied to random things and far apart.
I got further into the wiring and started pulling more things apart and labeling things. This wire below was connected to two wires on the leading coil pack thing and the yellow wire went from that splice to the alternator with two more butt connectors along the way.
I'm being really picky about the wiring and will end up rewiring most of it, but the car did run fine and everything worked.
Old 08-20-12, 10:50 PM
  #1192
Lapping = Fapping
Jeff20B's Avatar
Hooked up DLIDFIS in the blue car. Now it is easier to start (not that it was hard before), has a stronger idle (cold idle especially), more tip in (it just wants to go now), and the carb is a little smoother (the way it drives) as is the idle. I'll swap to a Nikki at some point to get more high end and even smoother running once it breaks in a little more.
Definitely a worth while mod that's cheap (free in my case). No clunky red boxes to deal with.
Old 08-20-12, 11:08 PM
  #1193
cruising around tonight, ive decided... i need more torque.... now starts the search for N318 boost sensor, knock box, ECU and MAF... if you know what i mean
Old 08-21-12, 02:21 PM
  #1194
13x
Sin City Rotary
13x's Avatar
air dam looks good on there!!
Old 08-21-12, 10:28 PM
  #1195
Oldschool
I did a lot of thinking about the car today, can't decide if I should tackle my brakes or suspension first both are in bad shape.
Also you guys NEED to check this out.
SA22C RX-7 part 2 | JDM Legends
It is honestly the ultimate widebody Rx7.
Old 08-22-12, 12:03 AM
  #1196
Always Wanting to Learn
DreamInRotary's Avatar
Went from this setup in the 7
With this true rat's nest behind it
To a more simple setup found here
Did I like the triple gauge pod? Yes.
Did I like having all that info at my disposal? Yes.
Did I like the location? NO.
Did I need an oil temp with a water temp? NO.
Did I need another oil pressure gauge? Most definitely NOT.
Most importantly - were they in a terrible location?? OF COURSE!
I would never recommend putting gauges in that location to anyone. I didn't need any more info for the oil standpoint but it was cool looking. I think I will be better off with the pocket space there.
I know that the water temp gauge being down by the feet is even more dangerous. But that's only installed to ensure proper e-fan thermostat temperature kick on, from a safety standpoint. And I drilled and tapped the sensor into the stock water pump outlet, so it can't go anywhere else anyways haha
Attached Thumbnails What did you do to your FB today?-kenwood-auto-meter-gauges-1-1024x768-.jpg   What did you do to your FB today?-imag0182-1024x577-.jpg   What did you do to your FB today?-imag0184-1024x577-.jpg   What did you do to your FB today?-imag0183-1024x577-.jpg
Old 08-22-12, 12:11 AM
  #1197
marc
themarc65's Avatar
such a good day
so my car wouldnt start for the past week. was about to go get a new starter, cause i could hear it crank but not engage. well i pushed it out of my drive way and had my wife help push it down the road to try and pop the clucth.(she was in our truck) well what do you know started right up. at that moment joy filled me like the first day i bought it.
Old 08-22-12, 08:50 AM
  #1198
79 w 13B4port
rwatson5651's Avatar
Originally Posted by OneRotor
You scared the **** out of me!!!!!
Old 08-22-12, 08:55 AM
  #1199
RAWR
OneRotor's Avatar
Why?
Old 08-22-12, 09:03 AM
  #1200
死*神*
Thank you sir, and thank you again for finding it for me. Once I get the car street legal, I can begin on other projects. Then when I begin the widebody project I can sell it back to you for the same price or I can cut it up to use as a plug like I originally planned. I just gotta get my own house before I can get serious with FG. For example I need a new hood because my TB smacks into it as is but can make a new one for a few months.
I will post more pictures of her. right now she has no exhaust, needs an alignment, and needs tagged. I was thinking I should get my gf to do a photo shoot with it. maybe even get a picture with me in it to prove she is my gf (you know how the hotties draw that kind of attention), just as long as I don't get the cradle robber comments about her and my age diference
Quick Reply: What did you do to your FB today?
