Help on Stalling Problem
Old 04-17-12, 10:30 PM
USMChris93FD's Avatar
Exclamation Help on Stalling Problem
So i'm out of ideas and completely lost on whats wrong with my FD now and I have about a week to get it running due to my wife recently starting school and my work i need a running car BAD.
So first with my mods:
power fc and commander
downpipe, hi flow cat, apexi catback
intercooler
intakes
radiator
So ive never had problems with the car starting or running, I changed the radiator about 3 weeks ago and after that the car would start for 4-5 seconds then stall. So last night i changed the fuel pump and fuel filter thinking it was a fuel cut making the car stall and that night the car started for about a minute then stalled a total of 3 times. My map sensor is not messed up so i know its not that. So today i dropped my power fc in for the first time and reset it to the base map and when i tried to start it the car would only crank and crank but not fire up. Any suggestions on how to fix it would be helpful, just need to get my car running so i can take it down to Neptune Speed on the 28th for a tune. Running out of time and options someone PLEASE HELP!
USMChris93FD is offline
Old 04-17-12, 10:38 PM
I'm a CF and poop smith
skunks's Avatar
Try putting back the stock computer back in and go through the deflooding procedures. if you were starting for 4-5 seconds and then stalling, it could be easily flooding. Make sure to check all your relays and fuses too.
skunks is offline
Old 04-17-12, 10:53 PM
96fd3s's Avatar
you could also try some hotter heat range plugs to get you going if you are indeed flooding.
try the stock bur7eqp and bur9eqp plugs if your not using them already.
96fd3s is offline
Old 04-17-12, 11:00 PM
skunks's Avatar
oh, forgot to ask if you had charged up your battery. never hurts to have it fully charged before you start cranking it over.
skunks is offline
Old 04-17-12, 11:18 PM
i've gone through the deflooding procedure, its not flooded
already using those plugs lol
my battery got charged the other day so i know its fully charged
Old 04-18-12, 12:07 AM
96fd3s's Avatar
did you do anything to your clutch by any chance?
maby check your clutch switch - your clutch may be applying pressure to the flywheel and stalling you.
96fd3s is offline
Old 04-18-12, 12:20 AM
ill check it out but ive never touched my clutch
Old 04-18-12, 09:07 AM
Cheap Bastard
adam c's Avatar
Try resetting the idle on your pfc to a much higher idle speed. Maybe 1500 ish. If that will keep the engine from dying, at least you can get it to the tuner.
adam c is offline
Old 04-18-12, 09:13 AM
Well the car won't even start with the PFC. Will changing the idle get it to start and how do I do that from the commander?
Old 04-18-12, 10:13 AM
Mr. Links
Mahjik's Avatar
You said this all started after installing a new radiator... Have you rechecked your work do see if you did something (on accident) like damage the CAS lines, knock a ground wire off, etc?
Mahjik is offline
Old 04-18-12, 10:48 AM
FFWD_FD's Avatar
did you remove the bumper to work on your radiator? did you remove the grounded wires mounted on the front support beam? check to see if the ground wires there are securely connected.
FFWD_FD is offline
Old 04-18-12, 11:33 AM
I didn't remove the front bumper but ill double check ground wires. Does anyone have pictures if what wore I should exactly be looking for?
Old 04-18-12, 11:39 AM
Recovering Miataholic
wstrohm's Avatar
With the stock ECU in place, have you looked at stored fault codes?
wstrohm is offline
Old 04-18-12, 04:47 PM
I'm nor throwing fault codes. Update: after trying to start with PFC there's a sound from under my uim that's sounds like light buzzing or electricity?
Old 04-18-12, 05:15 PM
Searching for 10th's
jkstill's Avatar
Do you have an HKS Twin Power under there?
They do that sometimes.
jkstill is offline
Old 04-18-12, 05:23 PM
no i dont
Old 04-18-12, 08:56 PM
Found 2 little wires unplugged under the uim, I think its called the BAC
Old 05-01-12, 11:15 AM
Fixed it thanks for the input everyone
toplessFC3Sman
03-20-18 01:54 PM
The1Sun
09-18-15 07:13 PM
xXBrendanXx
Power FC Forum
09-17-15 10:10 AM
REX7&Z32TT
09-09-15 05:16 AM
Steven_McKinley
09-05-15 10:48 AM
Quick Reply: Help on Stalling Problem
