Installing a 12v cigarette lighter?
Old 04-27-12, 03:21 PM
S5 GXL NA - S5 TII
Kenshin XI's Avatar
I bought a cigarette lighter for my FC since it had an antenna switch in its place and I need it to charge navigation systems and everything. I have no idea what to connect to what so what do I do?
There's also a blue wire with the metal piece at the end for the power antenna
Old 04-27-12, 04:37 PM
FC guy
Rob XX 7's Avatar
you ground the quick connect on the side, and the red wire you put to 12V and slide it onto the lighter, will probably have to cut the spade terminal off you wont be able to use it.
if you mean where in your car then get out a test light and start probing
Old 04-27-12, 06:07 PM
S5 GXL NA - S5 TII
Kenshin XI's Avatar
Alright thanks. its connected and works now but something happened and smoke started pouring from my radio so were gonna rewire everything tomorrow.
Old 04-28-12, 05:49 PM
FC guy
Rob XX 7's Avatar
once you let the smoke out it will not work any longer, you will need new smoke
Old 04-29-12, 01:36 PM
S5 GXL NA - S5 TII
Kenshin XI's Avatar
Well everything is connected properly and works. Where can I buy new smoke?
09-16-18 07:16 PM
SakeBomb Garage
Vendor Classifieds
08-09-18 05:54 PM
t-von
09-10-15 01:56 PM
Quick Reply: Installing a 12v cigarette lighter?
