rhd conversion parts list?
Old 05-04-12, 10:36 AM
13bturborx7's Avatar
Whats up guys. Does anybody know ALL the things i need to convert my fd to rhd?. I couldnt find a new lhd carpet so i bought the rhd carpet new. I might as well go full rhd so if anybody can please let me know what i need i would apprciate it i want to start checkin off this list.
Old 05-04-12, 10:46 AM
Boilermakers!
ZE Power MX6's Avatar
Only one thing on the list, full RHD front clip.
Old 05-04-12, 10:47 AM
Rotor or no motor
R-R-Rx7's Avatar
so wait, you bought a RHD carpet and you want to convert your car RHD? am i getting this right?
u would need the wiring harness, the steering rack, the RHD downpipe if u are still running the twins and a whole of other bunch of parts
Old 05-04-12, 10:59 AM
Yea i want a rhd front clip it would be nice to get one in really good condition. do i have to change the body harness?. I know the door harnesses are different.
Old 05-04-12, 11:00 AM
Supernaut's Avatar
Hmmm his logic is sound.
Speak to str8ryd. He did the conversion and did an excellent job of it. Personally, I think it's a total waste for you to do the conversion just because you have a new carpet. I mean...Wow. You must have some deep pockets. You might as well just buy a RHD car even if there is a chance of it getting impounded.
Old 05-04-12, 11:19 AM
Question
I want to be able to say i built the car myself. I always wanted a perfect condition rx7. And if i build it from the ground up i know i will have that perfect car. I finally have the job that allows me to do it so im just takin the bull by the horns nd getting it done. Thanks alot though supernaut il give him a shout hopefully he can help me out.
[QUOTE=Supernaut;11078907]Hmmm his logic is sound.
Old 05-04-12, 12:39 PM
zeroG's Avatar
So you're saying the car is currently just a shell/roller? Or are you going to be removing all the standard LHD interior and other parts and then replace them with a RHD?
Old 05-04-12, 01:07 PM
Yes its a roller. I bought every single interior piece brand new nd i wanted the carpet to.match so i bought the rhd carpet. I dont want any holes like from the fuel door latch so il just go ahead and just make the car that much sicker. I cant cut any corners.
Old 05-04-12, 01:44 PM
bufferovrflo's Avatar
Sounds like you need to make a build thread
Old 05-04-12, 04:08 PM
0piston's Avatar
Sent you a message i have a whack load of RHD parts if interested for sale or trade.
Old 05-04-12, 06:23 PM
Sir Braps A lot
rx7rcer09's Avatar
IMO with the money your going to spend why not but a LHD carpet from someone parting out a car and use the extra money you would have spent and put a 20B in or build an amazing 13B.
Old 05-04-12, 06:28 PM
Japan2LA's Avatar
I have ll the required parts..
Old 05-04-12, 07:46 PM
DRIVE THE ROTARY SPORTS
RotorMotor's Avatar
The conversion is really easy actually, it's pretty much all boltup
I've got some JDM rear interior panels if you want ...
Old 05-04-12, 09:30 PM
I already got the 20b. I want that and the rhd too. Im very picky. If it isnt going to be perfect i dont want it at all.
Old 05-05-12, 09:04 AM
do i have to change those back panels also? i bought brand new ones from mazda lol
Old 05-05-12, 11:22 AM
Robbierx7's Avatar
Off the top of my head guessing
Door cards
Complete Dash
Center console
Complete wiring harness for the whole car including engine harness
Heater assy
Brake lines, clutch lines, water lines (for the whole car front to back)
ABS mounting bracket
Wiper assy and wipers
Jap spec downpipe if running the twins.
You could get away with joining the LHD brake lines to the existing RHD lines, but if you want to perfect, i reckon you'll need the whole cars brake lines.
Basically, you need to find a complete rhd car. Any sane person would just do that car up instead unless a ton of money has already been poured into the LHD car. A LOT of work ahead if you do go ahead and convert.
Old 05-05-12, 12:30 PM
Door cards
Complete Dash
Center console
Heater assy
il just get a jdm half clip. im going to eliminate abs and il make my own brake lines so that wont be a problem. i got the greddy t78 turbo kit so i dont got to worry about that either. i just need the entire wiring harness i guess. i thought i would be able to get away with the dash harness and thats it. but well see what happends. im sure i can get a harness. theres alot more jdm rx7's then usdm.
Old 05-05-12, 05:54 PM
Narukas's Avatar
JDM dash and USDM rear body harnesses doesn't stack up actually. Fuses and relays are located in opposite sites so basically all the wires to the rear end run in somewhat different route, connector pinout's are also different. And more to this some of the wires connecting front harness and rear run through dash harness.
I had some joy in comparing JDM and USDM wiring harnesses when doing my H11 ABS swap.
Adopting JDM harness would be really difficult.
Knowing that I would also recommend another RHD car, or you could make custom dash harness which in a long term would less PITA.
Old 05-05-12, 06:04 PM
Robbierx7's Avatar
Yup, Which is why i said he needs the whole car's wiring and not just the front end. My fd is a typeR jap import and sitting in the car, the ecu is on the left, fusebox on the right.
Old 05-05-12, 10:24 PM
Im going to have to get a full harness then i guess. Would i be able to get this in the japan market?. Or should i get it new?
Old 05-06-12, 01:02 AM
bow leggin'
Scrub's Avatar
Just flip the carpet inside out and it's a LHD carpet
Let me get your logic straight....
LHD carpet can not be found...Purchase RHD carpet and refit the ENTIRE CAR to match.
Wow now that I've written it out and read over it, it makes complete sense. Good luck!
Old 05-06-12, 01:05 AM
Old and grumpy
cabaynes's Avatar
Old 05-06-12, 01:17 AM
Old and grumpy
cabaynes's Avatar
Old 05-06-12, 06:13 AM
Can you blame me for not cutting any corners?.
Old 05-06-12, 11:55 AM
bow leggin'
Scrub's Avatar
Cutting corners is different then taking a dirt path that leads to a cliff into a pit of despair.
How do you associate cutting corners with buying the wrong carpet and then changing the entire car to match? Not sure what you're trying to prove by saying you built the car yourself or converted it to RHD. But hey it's your time and your money if you want to waste massive amounts of both, go for it.
Quick Reply: rhd conversion parts list?
